Canon DC210 DVD Camcorder Logo
janine zipchen Posted on Dec 23, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't read the disc
Initializing ... won't let me record
Josh Whitehead
Level 3:
Genius:
  • Master 1,148 Answers
  • Posted on Dec 23, 2011
Josh Whitehead
Master
Level 3:
Genius:
Answers
1148
Questions
Helped
247546
Points
3024
Try another disc,,,could be bad disc,,,check ur samsung website for support ,,,and get a disc cleaner,,for ur cam corder,,good luck
Cd recorder won't read blank cd
If it is a older CD Recorder, You have to use disc,s that stay music on the label. Disc,s for burning music from a computer will not work in them,
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
Sony disc player just hissing not plalying
Hello, i just found one of these decks yesterday with the same problem. The deck loads a disc correctly, but cannot read the TOC (doesnt display the title or track number)
The hissing sound is actually the sound of the laser lens vibrating in a unfocussed manner
The solution: 1.Use a minidisc lens cleaner if available.2.If not, eject the minidisc and open the deck. Take a good look at the laser lens. Is it dusty or seems hazed over (cigarette fumes)? (Mine was)
If yes, clean the laser lens directly with a cotton swab to which you add a drop of isopropylene (100% alcohol) or (2nd best choice) window cleaner.
Take care to not bend of break the recording head (the white and copper arm just above the lens)
use a dry cotton swab to pick up any remaning humidity on the lens.
3. Try again to read a disc. any success? No? try, if available, a pre-recorded disc
any sucess then? Chances are it might work with a pre-recorded disc because of the better reflectivity of these discs.
No luck yet? Doest it read some discs, others not? well, it's time to re-adjust the deck. The service manual is available here: http://www.minidisc.org/manuals/sony/service/sony_MDS-JE520_service_manual.pdf for free. BTW the site www.Minidisc.org is an exellent source of all information available about minidisc.
First let the deck tell you what the problem is! Page 2 explains how to enter the self-diagnosis mode. Enter the Error DP (display) mode. Look at the error history. Most probably you will find the code E06 (as i did) which means Focus error.
The service manual explains how to enter Adjust mode.
Keep an eye on the C1 error 7350= doesnt read correctly 0-50=adjustment ok.
Do C(ontinous)-play checking: 5-6-5 MO error rate check (Page 38)
Perform focus bias adjust (page 41) (5-12) This is a manual adjustment Keep an eye on the C1 error 7350= doesnt read correctly 0-50=adjustment ok.
Keep in mind that you have to adust the setting "A" with the AMS button to obtain C1=220, and "B" turning the AMS button downwards (anti-clockwise) to obtain C1=220 the deck calculates automaticaly the adjustment "C".
Perform autogain control level output adjustment for MO discs
(page 42) (5-15-2)
If this doesn't work, reset the deck to initial settings / Initial setting of adustment settings (page 39).
Perform focus bias adjust (page 41) again (the deck displays the adress and C-1 and ADER errors)
Check if the adjustment is ok with C-play checking 5-6-5
(page 42) again (5-15-2)
MO-disc= recordable MD
Hopefully you can re-adjust your deck. You don't need any extra tools for this, the deck displays the error rate. In C-play mode, a pre-recorded disc shows nearly always 0 C-1 errors, a recorded disc should not show more than 50 C-1 errors and no ADER errrors.
Of course this is at your own risk. I can only say that i needed about 1 hour to find the setting which worked with different recorded discs.
There is also the Continuous recording mode to check that the error rater during recording stay within tolerance. If you use this mode bear in mind that the disc will be (partially) erased regardless if fully or partially recorded. In test mode there is no safeguard against accidentaly erasing, so use a new disc or one with a recording you don't care to loose.
Simply unplug the deck to exit the service mode.
Check if you can record after adjusting the focus. Check if you can enter a title to the disc. Is the title there when you eject and reload the disc? If yes, you succeded!
Hope this helps!
P.S. Yes, i once was working for Sony as a repair techncian...
1helpful
2answers
I just purchased a 5300 home theatre system. When I insert a blue ray disc, it will play the previews, but when I hit the play putton, it goes to the settings menu. What seetting have I missed?
I would suggest to read on the owners manual first before operating your machine.and you can avail of the warranty if you found problem n your playaer...
I have a panasonic dmr-75v dvr and it won't read blank dvd's.i tried 3 different brands of dvd's with no luck of
This machine will only accept DVD-RAM & DVD-R Discs.
All other formats of Recordable DVD will be rejected for either Recording or Playback.
Please leave feedback.
Cheers
Andy
My Pioneer PDR 555-RW keeps reading Mon1 or Moni when I try to record my CD from my mixing board. I need to send this wedding music, and it is trapped in my board. HELP!
That's just a MONITOR indication. It means you can SEE the audio from the selected input on the record level meters for adjustment or other reasons. It won't prevent you from recording. Set your levels then hit RECORD, let it set itself up and calibrate to the disc, start your source and hit Play or Pause to start recording to the disc.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
