Apple iPod MA446LL/A MP3 Player Logo
Anonymous Posted on Dec 23, 2011
How to there is itunes in ipod - Apple iPod MA446LL/A MP3 Player
kenneth njonjo
Level 3:
Top Expert:
  • Apple Master 1,575 Answers
  • Posted on Dec 23, 2011
kenneth njonjo
Apple Master
Level 3:
Top Expert:
Answers
1575
Questions
Helped
365525
Points
4558
Hi Saad,
Get free itune downloads,video tutorials and how-to's with your itunes on this link: www.apple.com/itunes/how-to/
Hope this helps.Thanks!
Anonymous
Level 2:
New Friend:
  • Expert 76 Answers
  • Posted on Feb 27, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
76
Questions
0
Helped
29021
Points
137
And you also can turn to this iPod spot: http://www.ifunia.com/iphone-column/index.html
3answers
Ipod classic music download
You need to add songs to iTunes library and then sync them to iPod. The guidance below will introduce you how to transfer music from computer to iPod with iTunes in detail.
ipod-classic-music-download-oxaxc0rwhkhzilrwacqreyis-1-0.jpg ipod-classic-music-download-oxaxc0rwhkhzilrwacqreyis-1-2.jpg
Of course, here's also a guide to help you transfer music to your iPod without using iTunes. How to Transfer Music to iPod without iTunes
1helpful
2answers
I tried to get itunes on my ipod
You just need to import your songs into iTunes library, then make a playlist with the songs, connect your iPod to computer, iTunes will detect the iPod automatically, then click iTunes menu "File -> Sync iPod", the songs will be transferred from iTunes to iPod. Or You may try this ipod transfer, it's a nice iTunes alternative that can help you manage iPod files including delete, upload, play, copy, etc. It's much easier to use than iTunes.
When i plug my ipod on to itunes it wont show up
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
My ipod wont show up on the bar when i plug it in the itunes
5answers
Songs from ipod onto computer
iTunes is always the best tool for us to transfer music from iPod to computer or from computer to iPod, but for the situation of transferring music from iPod to new computer with iTunes is really difficult.
But there are some ways can help us to achieve it, like belows.
http://support.apple.com/kb/hT1329
http://smartphonething.blogspot.com/2012/07/how-to-transfer-music-from-ipad-to.html
http://www.leawo.com/knowledge/transfer-music-from-ipod-to-computer.html
2answers
I cant download to my ipod i cant get sync in itunes..how do i download songs to my ipod
If iTunes not works for you, You may try this ipod transfer, it's a nice iTunes alternative that can help you manage iPod files including delete, upload, play, copy, etc. It's much easier to use than iTunes.
How to load audio cd that's mp3 readt to a ipod
you can use Itunes to convert all Mp3's to an Ipod Format that's the only best and sfest way to prevent any corruption to the files and to the Ipod itself.
Once you installed Itunes on your PC, search all the Mp3's to have it sync to the Itune program conenct your Ipod Itunes will detect the Ipod and ask if you would like to sync your device "ipod" with Itunes I suggest you select no do not sync the ipod to youe Itunes any changes on the Itunes when you sync your Ipod will also change the way you have your Ipod setting. once the Audi Files are detected by Itunes you can drag all the music you like to your Ipod's Name on the Left side it should show once you connect your Ipod this is the only way you can upload Mp3 files to your Ipod if you don't use Itunes the Audio File may be installed in your Ipod but may not run, Apple has a different Format this is the reason why you need Itunes.
4answers
My ipod touch will not sync my music from itunes
Hey! There are some other iPod Transfer tools which can transfer music between iPod and PC, iPod and iTunes freely. I am now using this Wondershare iPod Transfer which is very easy-to-use. Now I can transfer music between iPod and PC, iPod and iTunes easily. You can have a free try of it.
Hope that will be of help to you.
2helpful
3answers
How do i put movies or videos in my ipod 4GB?????? plz
only 3rd generation iPod nanos can play video, and the video must be mp4, you can use itunes to sync video to ipod nano, just follow those steps:
1. Open iTunes and click "File" to add your videos to iTunes library.
2. plug in your iPod Nano to computer, then iTunes will detect your iPod Nano as a device.
3. Select your iPod Nano device on the left panel of iTunes, click "Movies" tab, check the videos you want to sync and click "Apply"
4answers
Transfer music from one ipod to another
I recommend you am iPod to iPod/Computer/iTunes Transfer which can transfer your iPod and iPhone music, video, playlist, photos back to computer and iTunes.
If you own more than one iPods, AVCWare iPod to iPod/Computer/iTunes Transfer can simultaneously manage all the iPods in the same interface, you may transfer files among these iPods by drag-and-drop.
Hope it helps!
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
