Cd is not recognised in my computer and the cd tray will not even open
SOURCE: Problem with sony crx880a cd/dvd drive
It sounds like you have already tried everything I can think of. I would be looking at the actual drive and maybe considering a replacement.
SOURCE: CD/DVD tray opens on its own- Dell Inspiron 510m
The lock on the drive is failing, you'll need to replace the drive.
http://cgi.ebay.com/DVD-RW-drive-Dell-Inspiron-300m-500m-510m-600m-610m-M20_W0QQitemZ280435221123QQcmdZViewItemQQptZPCC_Drives_Storage_Internal?hash=item414b3de283#ht_2162wt_1165
SOURCE: tsstcorp dvd+-rw ts-l632h cd/dvd not working.
Reboot and hit F12 to run Dell Diagnostics on the drive. It does sound like it could be bad.
If it is, you may need to replace it.
These drives have been failing a lot lately, and even the firmware patch is not helping.
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps you
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
you might
have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate
you might have to uninstall then reinstall your DVD/CD or uninstall the
driver then reinstall for this device
Click start control panel administrive tools,computer management,device
manager scroll down cd-dvd rom drives you might see a yellow question mark
? right click you will have options to update driver,roll back driver,or select
click update driver or uninstall then reinstall if this does not fix the
problem it might be a registry problem if you cant see your disk drive in
windows explorer
Close all open
programs
Click on
Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
