Janome Hello Kitty 11706 Mechanical Sewing Machine Logo
Tonya Martin Posted on Dec 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Instruction manual gave machine to my daughter but it didn't come with manual , and we're having trouble with the bobbin any suggestion
Irene Tulloch
Level 2:
  • Expert 498 Answers
  • Posted on Dec 24, 2011
Irene Tulloch
Expert
Level 2:
Answers
498
Questions
0
Helped
119351
Points
994
There is a free manual for the chainstitch Hello Kitty which may, or may not help. try here. http://www.nkok.com/FCKFiles/File/4303%20Lockstitch%20Manual%20&%20Project.pdf
Other than that you may need to buy a manual from some of the online sewing machine manual sellers
1helpful
My Bernina Activa 140 (12 yrs. old,first time to have any trouble with it) has stopped stitching properly. The top thread looks normal but underneaty(the bobbin thread I guess) is just giant loops an
Almost every time this will be due to the machine being not threaded correctly. I've been sewing for 45 years and still mis-thread my machine occasionally. It's also possible that the bobbin thread didn't seat quite right when you put in the bobbin. Or, I've had mine do that if I didn't quite get the presser foot lever down completely. (working with heavy fabrics usually)
If that is not the case here, try replacing your needle with a new one, as it might have developed a small burr, and be certain that it's the correct needle for the fabric. Sometimes it can also be that the needle is in backwards. Also, cleaning it, (the bobbin area), out thoroughly by using a soft brush and some canned air can do wonders for it. Then use a drop or two of sewing machine oil where your manual indicates it to go in that area.
If none of that fixes the problem, let me know and I'll see if there is a problem specific to your machine that can happen.
Happy Sewing! :)
1helpful
Bobbin bouncing problem
Sounds like you didn't get the bobbin holder inserted correctly.
Here's a download of your manual if you need it.
http://content.janome.com/documents/File/ManualFile/Inst%20book%20MC10000%20book%201.pdf
PDF page 74 has the instruction on how to take out and put it back in correctly.
Good luck
I have a Singer Touch and sew 600e, the bobbin thread is all bunched up and machine jams up with thread. How can I fix this? Is there a simple setting that I am missing.
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is inserted correctly in the bobbin case
make sure the top thread is not coming off the thread take up lever
make sure the bobbin is wound correctly
if these suggestions don't work, I suggest that you take the machine
to a sewing machine shop to have it checked
3helpful
2answers
Singer 758 model and the thread is bunching up from the bobbin under the material
try changing the needle--flat side goes to the back of machine
rethread the machine top & bobbin--make sure to use every thread guide
make sure bobbin is wound correctly & inserted correctly in the bobbin case
clean under the needle plate & in the bobbin area for lint or loose threads
if you don't have a manual try singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number(example 758)
Click search
1helpful
Singer Athena 2009 needle hitting plastic in bobbin case
here's something to check
is the needle inserted all the way in to the needle holder?
needle--flat side goes to the back of the machine
is the needle clamp screw tight or loose?
if the needle is correctly in the needle holder & the needle clamp screw is tight --then the needle bar is out of time & need to be serviced
IF YOU DO HAVE TO TAKE IT TO BE SERVICED AFTER YOU GET IT HOME STOP RIGHT THEN & SEW ON THE MACHINE TO MAKE SURE THEY FIXED THE MACHINE & IT SEWS LIKE IT SUPPOSE TO, I HAD ONE CUSTOMER THAT TOOK THEIR MACHINE TO A SHOP & THEY CLEANED IT AGAIN & DIDN'T FIX IT BUT CHARGED THEM FOR IT & THEY BROUGHT IT TO ME TO FIX & IT HAD TO BE RETIME
did you get a instruction manual for the machine if not check at singer
In the box type the model number---2009
Click search--if you don't see a manual--contact singer customer service
3helpful
2answers
What size are the bobbins for the memory craft 8000? I've compared the class 15 to my original bobbin but the class 15 has a ridge that my original doesn't have...the class 15J is more like the...
You need a bobbin like this:
You can puchase them from this link
http://www.sewingpartsonline.com/bobbins-janome-kenmore-elna-102261103.aspx
Janome have one standard plastic bobbin that fits almost all their models except
1600P, 1600P-DB, 1600P-DBX and MB4.
So if you see packets of plastic "Janome" bobbins for sale they will be the right ones.
I can't thread my bobbin. I get a error on the number guide and it is 88. so what is wrong with it not working.
Do you have a manul for your machine?
you can download it from here http://www.singerco.com/uploads/download/467_7466_efs.pdf
I can't see anything relating to error message 88 in the manual.
So I would suggest you start by trouble shooting the bobbin case, go to page 76 in manual and folloing images, take out bobbin case, clean and replace it. Turn machine off first and once its back in turn it on and see if the 88 code has reset.
Then redo bobbin winding, and threading up. Start with the manual instructions on this page 18 and 20 and work through it step by step. Make sure bobbin is in the right way so thread is feeding off in the right direction. Also just a thought, you haven't got a stray bobbin in there that isn't a Singer one??
I hope that this helps you to eliminate your machine problem, obviously if this doesn't solve it you may need to take it for a service and see if the 88 display relates to something within the machine circuitry.
I'm in trouble deep-I was trying to fix an old
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Having thread breakage probelm and also can't track down the correct bobbin to use on the Elna 2005
have you got the manual for this machine? You can download one from here: http://www.ps2netdrivers.net/manual/elna.2005/
It is a front loading bobbin and removabel bobbin case so I think the bobbin is a plastic "Class 15" - like this http://www.sewingpartsonline.com/bobbins-class-15-plastic-10-pack.aspx
Thread breaking could be caused several factors such as the thread actually being old and brittle, the needle or needle plate having burrs and catching the thread, incorrect threading, bobbin in bobbin case the wrong way, or top tension discs playing up/too tight or thread catching somewhere in the threading path.
I'd suggest that you trouble shoot this and refer to the manual for cleaning instructions. If you can access them clean between the tension discs (turn tension down to zero and "floss" between the by running the selvage edge of a piece of clean cotton scrap through the discs to remove any lint/dye buildup). Wind a fresh bobbin and rethread referring to the manual to ensure the bobbin is turning the right way. New needle and rethread top thread refering to threading diagram. Tension on 5 and test sew again.
If you are still having problems, then the machine may benefit from a service by your local Elna dealer, a good service and clean at least every 2 years is recommended.
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
