Won't complete cycle and water remains in base
Hi Thanks for using FixYa. If the cycle doesn't
complete, then the first thing that should be checked is the Timer and then the
heating element. Timers don't often fail. But if every other part of the
dishwasher seems to be working properly and the timer knob seems to be stuck in
one place--doing one function continuously--the timer may be at fault.
Dishwasher timers can't be repaired. If yours is defective, replace it. Many
dishwashers heat the wash and/or rinse water to a higher temperature, as the
cycle calls for it. In these cycles, the dishwasher pauses after it has filled
with water, waiting for the water to reach the pre-set temperature. What
happens next depends, as follows: On some units, the pause is timed and the
unit continues after the allotted time. On others, the cycle can't continue
until the water reaches the higher temperature. If you have this type of
dishwasher and the water isn't being heated (say, because of a problem with the
heating element or thermostat), after the unit stops at the heating cycle, it
never continues. When you repair the heating-system problem, the "cycle
problem" is fixed too. Please accept the solution if the
issue is resolved or post a comment for further assistance. Thanks Rylee
SOURCE: whirlpool dishwasher drainage problem..
This sounds like a bad timer. The timer is what tells the pump to drain at specified times. If it gets a bad contact, that timed cycle won't happen.
PS: Do you know for sure that the drain is occurring in mid-cycle? If not, you may just have an obstruction in the drain and/or anti-siphon valve (where the hose connects under the dishwasher.
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
SOURCE: water in the dishwasher after the the cycle is complete
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
SOURCE: Bosch Dishwasher, model SGS6312GB/07. The water
press cancel/drain sequence to get water out-check owners manual.
2 possible solutions to your problem discussed here:
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
problem may be a burnt out solder connection on circuit board
call bosch to see if it recall issue
SOURCE: the dishwasher won't drain completely.
I have an Indicit IDL60 dishwasher, it didnt drain prooerly then the 12H light came on, and it will not respond to anything other than light u the 12H light. My book doesnt tell me what that means, any clues, thank Jenny
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn
