My tumble dryer WTE84122BY keeps switching off after a few min. The second bottom light then flashes. I presume that's the condenser light? Didn't receive an english manual only every other language imaginable.
? 2:33
https://www.youtube.com/watch?v=uWtRXie82oY
Nov 17, 2011 - Uploaded by BuySpares
For all your tumble dryer spare parts and accessories, visit: http://bit.ly/1K45iyb If your tumble dryer isn't ...
? 8:52
https://www.youtube.com/watch?v=75l_AtpGkks
Dec 6, 2009 - Uploaded by how-2-repair.com
http://www.how-to-repair.com/help/repair-guides/tumble-dryers/ This usually means ... Up next. Whirlpool ...
Unfortunately, it means you have a computerized machine that can only be repaired by a technician with proper diagnosing equipment. Even if you can find out the meaning of the code... that may not tell you what to do about it. (It usually involves replacing circuit boards). Monetarily, with regard to cost of repairs, we were all far better off back in the days of ''switches'', ''knobs'' and ''mechanical timers''.
Did you check the res to see if it was full? Might be clothes inside the door and it aint shut all the way? never even seen a condenser dryer.
I have the model service manual though HERE
Make sure the condenser is pushed back in palce correctly. If tghe eoor persists then tun off the AC power to the machine and wait for 30 mins. Then power it back on. The fault should clear but of not then you may have a fault with lelvel switch
There are three water reservoirs - one at the bottom behind the condenser, a second at the back bottom of the machine and then a third at the top which is the one you would normally pull out to empty.
There is a hole at the bottom of the filter in the first reservoir (at the back of the condenser) which leads to the second reservoir at the back. If the hole gets clogged up with lint/muck then the reservoir at the back does not fill up.
So to solve this, unplug the machine, take out the condenser (front left bottom of the machine) reach through to the back and mop up the spare water with a towel and check that the hole to the back reservoir - you can feel this it is towards the right side at the back of the machine is clear from muck.
Once you have cleared it, water will flow to the second reservoir and then (once you switch on the machine) up to the main removeable reservoir at the top.
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
