Question about Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181)
I have a Hauppauge WinTV HVR-1600 - ATSC HDTV receiver in my HP Media Center PC m7760n I have a comcast digital box hooked up to my PC but it seems after a while my screen starts to go on and off. Signal is bad and black and white media. I was wondering if maybe the card in going bad
I have a Hauppauge WinTV HVR-1600. I have a comcast digital box hooked up to my PC. Signal is bad and black and white media. I installed the "current" driver two weeks ago (mid October) Work great! We had to perform a PC recovery. I downloaded the "current" driver. Got weak signal and black and white only.
Posted on Nov 02, 2008
SOURCE:
I have a HP Media Center PC 470n. Is there another card just for that PC. I have the wintv- hvr 1600,not as happy as I thought I would be.
You can use any capture card you want as long as you have a slot on the mother board. Media Center works with almost every capture card.
Having said that, i found hauppauge a great capture device what was it you didnt like?
Jan 06, 2010 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Windows media center can not find ir receiver
be sure you have installed the driver. If you are using windows 7 you still need to install the winTV driver. I know this because I had the same problem. It should work then. Just go to TV setting in the media center setup and it should scan for channels.
Jul 07, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Tv tuner
Basically what I can see from what I have read one had dual tuner capability and one is set up for PCI Express. Both look like great cards.
http://www.hauppauge.com/site/products/data_hvr1600.html
http://www.hauppauge.com/site/products/data_hvr1800.html
Thanks
Armymason
Feb 24, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Digital Transition
It's analog.  You need to purchase a digital receiver.  I personally have a USB external digital tuner running in Media Center 2005.  Search Ebay for "ATSC usb".  There's a lot of different options and most of them are pretty inexpensive.  To use a digital tuner in Media Center 2005, you have to leave the analog tuner / tuners in also.  You should still be able to use your current remote control with the new digital tuner.
Jan 25, 2009 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
No Audio with WinTV-HVR-1600 when tuning on S-Video
okay after more reading I found I needed to hook up the A/V output on my camcorder to my line-in input on the capture card (WinTV-hvr-1600) and now audio is working!
Nov 19, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
WinTV-HVR-1600 Tuner card to DishNetwork receiver
Yes, but what it can connect to depends on what Dish DVR you have. The newer, HD ones only have HDMI, S-Video, and that 5-split coax as outputs for the main TV since you only get these box's if you have and HDTV.
This is because regular old coaxial is no longer good enough for them. This means you must connect the newer DVR's to the S-Video input on the Hauppauge1600 since it is the only input to the card the Dish DVR supports.
If your DVR is older and has the coax out, you can use that and connect it to the Hauppauge analog input.
Nov 10, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Hauppauge WinTV HVR-1600 - ATSC HDTV receiver / analog TV tuner / video input ad (1181) Logo
1,061 people viewed this question
Top Hauppauge Televison & Video Experts
donshafer
Thomas Stauber
Thomas Stauber
Are you a Hauppauge Televison and Video Expert? Answer questions, earn points and help others
