HP LaserJet 4250n Printer Logo
YOLANDA CASILLAS Posted on Dec 20, 2011
49.ff95 service error HP LASERJET 4250N - HP LaserJet 4250n Printer
Techmaddy
Level 1:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 11 Answers
  • Posted on May 11, 2016
Techmaddy
Contributor
Level 1:
New Friend:
Night Owl:
Answers
11
Questions
0
Helped
8547
Points
18
I would start by removing the old driver, and make sure the print Que is empty.
Did you upgrade the firmware? If not I would.
1 Related Answer
Anonymous
  • 125 Answers
  • Posted on Jan 10, 2009
SOURCE: support
49.XXXX
PRINTER ERROR
To continue turn off then on
A critical firmware error has occurred that
caused the processor on the formatter to
abort the operation.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the printer. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 Service
Error
1 Press CANCEL JOB to clear the print job
from the printer memory.
2 Turn the printer off and then on.
3 Go to www.hp.com/go/lj4200_software,
www.hp.com/go/lj4250_software,
www.hp.com/go/lj4300_software, or
www.hp.com/go/lj4350_software.
Select Download Drivers and
Software
. Check for the latest firmware
image version at the bottom of the
page. If this firmware image is newer
than the one installed on the printer
and the printer can receive a firmware
update, download the newer firmware
upgrade. Not all
HP LaserJet 4200/4300 printers can
receive firmware upgrades.
4 Try printing a job from a different
software program. If the job prints, go
back to the first program and try
printing a different file.
hope this helps you
pdouglasss
1helpful
49 ff95 service error
49.XXXXX ERROR alternates with To continue turn Off then On 49.XXXXX ERROR alternates with To continue turn Off then On
Explanation
A critical firmware error has occurred.
Recommended action
  1. Turn the printer Off and then On.
  2. If the message persists, contact HP Support.
FF95 SERVICE ERROR CODE IN PRINTER
Does it give a 49.FF95? As their is no such error code "FF95" for a HP 2420. However I've seen 49. XXXX error codes before (XXXX meaning weird Alphanumeric Characters and numbers). This type of error code you can try a couple of Items:
1st - Perform a Cold Reset:
1. Turn the printer off.
2. Hold down the SELECT button, and then turn the printer on. Continue holding down
the SELECT button until all three printer control-panel lights flash once and then
remain on. This might take up to 10 seconds.
3. After the message SELECT LANGUAGE appears on the display, press the
UP ARROW button or the DOWN ARROW button until COLD RESET is highlighted.
4. Press the SELECT button. The printer performs a cold reset and then continues its
power-on sequence.
5. Check all I/O settings and reset any customer-set printer configuration values
If the machine still comes back to the Strange FF95 error I would start with the replacement of the formatter,
Part Number for the Formatter:
Network versions Q3955-60003
Non-network versions Q3953-60001
Hope this helps..
1helpful
You need to get a technician in. The code is suggesting the formatter board.
Note that make sure that the technician (or you if you are replacing it) that once you replace the board and turn on the machine, don't do anything for about 10 minutes. No printing, nothing. Take out the network/usb cord out to prevent anyone from printing. The reason is that the NVRAM (memory) is updating the new board with your information. If anyone prints (whether from a computer or a configuration page) then it will interrupt the update and you will get the same error again.
Go to HP.com. In the Support section you will find documents to help you troubleshoot this problem.
1helpful
How do i clear an 49.4C18 error message on a HP LaserJet 4250n?
Any of the 49 errors are from the formatter board, you may need new memory, or a new board. The machine doesn't reset from this error without a new board.
49. FF95 error
Hi hasan_taff:
What model HP is it?
2helpful
2answers
49.FF95 SERVICE ERROR
Please look on: http://www.fixyourownprinter.com/
There are much solutions of this problem listed ...
For example this (it see good):
http://www.fixyourownprinter.com/forums/printer/46157#1
HP Laser Jet 4250n by TLYNN (3/20/07 12:22 PM) reply + / -
Anybody know the error code "49. FF95 Service Error"
We can't get around this...
Firmware Error 49 by Stephen (edited 3/20/07 12:29 PM) reply + / -
It could be a bad job.
First disconnect it from your network and any PC it might be attached to.
Power cycle it, then if it goes to ready status try the built in test pages, do they work?
If the printer will go to ready status and you have a parallel cable with the proper connector, then you can try upgrading the firmware from a PC, you can also try to upgrade the firmware over the network.
More reading:
http://www.fixyourownprinter.com/search/forums?f=&q=49+4250
Re: HP Laser Jet 4250n by TLYNN (3/20/07 12:59 PM) reply + / -
Still won't go back to ready status. Turns on to the same error code....
Cold Reset HP Laser Jet 4250n by Stephen (3/20/07 1:03 PM) reply + / -
Try a cold reset, it will reset the JetDirect settings, but it's the next step.
Cold Reset:
Power off printer, wait about 5 seconds, then power it on, when asterisks start appearing on the display press and hold the check mark until all 3 lights come on solid, then use arrow keys to find cold reset and push check mark to perform the reset.
Re: HP Laser Jet 4250n by TLYNN (3/20/07 1:06 PM) reply + / -
Thank You so much for your help... but that didn't work either. Same error code showed up.
Re: HP Laser Jet 4250n by Stephen (edited 3/20/07 2:27 PM) reply + / -
Then you probably need to replace the formatter.
Do you have another printer you can swap parts with?
There is a slim chance the memory DIMM is bad, you can try it with the DIMM removed, if there is more than one DIMM you can try installing just one and then the other.
A 49 error indicates that the formatter could not understand or execute an instruction within a file or cannot interface with an accessory, DIMM, or EIO device. Troubleshooting 49 errors is done through process of elimination. First determine if the printer functions in a stand-alone mode then test communications to the printer.
These errors can be divided up into two categories; the associated troubleshooting depends on the circumstance the 49 errors are occurring.
A 49 error is always followed by Hexadecimal numbers, for instance, 49.00FF. The Hex code is a memory address. Most Hex codes are not documented.
Re: HP Laser Jet 4250n by dmzcompute (3/20/07 2:26 PM) reply + / -
I do not see anywhere where the printer has been disconected from everything. If you have not done so already disconnect every cable from the printer with the exception of the power cable and turn the printer back on and see if you get the error and if not report back here for further instructions.
Re: HP Laser Jet 4250n by Stephen (3/20/07 3:28 PM) reply + / -
You might also try disabling the embedded JetDirect.
To disable the embedded LAN port
Turn the printer power off.
Power on the printer and watch for the memory count to begin.
Hold down the SELECT (Checkmark) button, when you see the memory count begin.
Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until EMBEDDED LAN DISABLED appears on the display
Press the SELECT (Checkmark) button. The printer then continues its power-on sequence with the embedded LAN disabled.
If this works the JetDirect built into the formatter is bad, you can either replace the formatter, or buy an JetDirect to install in an EIO slot.
Re: HP Laser Jet 4250n by Trev Pearson (3/20/07 10:08 PM) reply + / -
The only other thing to try, before spending money, is to get the network administrator to clear the print queue for that particular printer and then turn it on.
The theory being that a 'corrupt' print job is still in the system and as soon as the printer is turned on, that 'corruption' floods the network card with garbage which promptly goes 49.
If the printer comes 'ready', great. Then do a firmware upgrade. If not, then you will have to spend money on a new formatter.
Regards
Trev
Re: HP Laser Jet 4250n by roadrunner178 (6/21/07 2:09 AM) reply + / -
hi.
With a cold reset ,my problem solved.
try this as a first solution.
thank you
Re: HP Laser Jet 4250n by Anonymous (7/31/07 1:20 AM) reply + / -
THANK YOU WERY MUCH
FROM TURKEY
ZAFER
Support
49.XXXX
PRINTER ERROR
operations.
Error
Software
upgrade. Not all
hope this helps you
pdouglasss
9helpful
49.FF95 SERVICE ERROR HAVE ANY SOLUTION
I have an HP Laserjet 2420 printer. And it's really bothering alot, it has an error 13.06.00 and also 13.20.00. What shall i do? I tired to clean the falg sensor and replaced the end sensor, but still there is no progress. Please i need help ASAP.
k24674
Grand Canyon Tech
Grand Canyon Tech
