Have set timer properly (the colon is flashing), and 3 hours appear on the display. The readout does count down, as "if" the breadmaker is working. The ingredients just sit there. No mixing occurs. The paddle has been pushed firmly down, and is in proper position. The bread pan locks properly into position when pushed down. What else could the problem be? I've read/re-read the instructions and have done everything properly.
SOURCE: Regal parts?
Go to e bay. They have a couple of stores that sell nothing but parts for bread machines.
SOURCE: West Bend breadmaker 41030 needs knead bar
try here maybe measure your part then maybe a sub will work if someone can send you the specs.
http://www.nelsonappliance.com/search_results.asp?txtsearchParamTxt=paddle&iLevel=1&txtsearchParamCat=ALL&txtsearchParamMan=ALL&txtsearchParamVen=ALL&txtsearchParamType=ALL&txtFromSearch=fromSearch
SOURCE: replacement mixing paddle for cbm 310 automatic breadmaker
07XTM34923 AbtecParts.com
Toastmaster Bread Machine part - works great, according to other website
I ordered mine today
SOURCE: B&D Bread maker all in one
I think the problem is that the bushing - the tubing that the paddle passes through - wears down (corrosion) and jams after a few years. I took mine apart and found that was the case. So a new pan has to be ordered. I'm trying that out now via the B&D 1-800 number.
SOURCE: The ingredients aren't mixing. I have to take the dough out and
My experience with the machine is that it kneads perfectly, but you have to use ACTIVE DRY YEAST instead of another kind of yeast, and you have to throw the ingredients into the pan in order - do not mix the ingredients at all - just pour them in, and let the machine do the mixing. Except for substituting between BREAD FLOUR and WHOLE WHEAT FLOUR, do not substitute any other ingredients. This one is very picky about the type of ingredients that you use - not for the innovator :-)
-Tha Mp3 Doctor
