Question about Onkyo TX-SR605 Receiver
Onkyo tx-sr605 takes a long time to connect to devices for audio and video
Whenever the receiver is off and then I turn it on along with the tv and cable box/xbox/wii/ps3/etc., it takes about 5 mins before it will connect everything and begin audio and video to my tv. I cant seem to figure out what's going on. Does anyone else have this problem and know how to fix this?
  • John Davenport Jun 10, 2012
    I have the exact same problem....I thought the problem was my tv power supply because I've already had wornout capacitors that had to be replaced before, but when I bypassed the receiver the tv picture came on much more quickly (5-10 seconds). I'm thinking the problem is either the receiver's hdmi out or the power supply.
SOURCE:
  • 21 Answers
SOURCE: Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Posted on Sep 03, 2007
CremeStout
  • 126 Answers
SOURCE: Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Posted on Dec 03, 2007
  • 14 Answers
SOURCE: onkyo SR605 Remote not working at all.
Dear Bzambo,
The batteries on the remote are fresh? if so the remote might be bad.
Sidlahora
Posted on Dec 06, 2007
  • 6 Answers
SOURCE: cable connection to Onkyo TX-SR605 7.1
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Posted on Jan 09, 2008
SOURCE: Onkyo TX-SR605 conected to Mitsubishi DLP TV
What I think I did and how I fixed it!
FACTORY RESET ON EVERYTHING!
All you have to do is to do a factory reset on everything, but I thing mostly on your 605, but I would do it on the TV as well. I think what had happened is after I set everything up for the first time, it worked great. As the days when on I started to play with all of the futures the 605 and the TV had to offer. I was turning them on and off to see what everything did. What I think I did was, I turned on something in the 605 that the TV did not know how to cope with. If I had to guess, I think it is the Lip-sink feature (Spelling?) in the 605.
Anyway disconnect everything, look in your manuals of the TV and the 605 to see how to do the factory reset on both. Then turn your TV on. After it does it’s start up for the first time (again), start connecting the 605.
It has been working great for me after I did this. Do not count on help from the people you bought it from or the people who made it. This stuff is so new they do not really know how to fix it.
Robert…
Posted on Jan 27, 2008
I am trying to get the amp working through my tv using HDMI leads. I have no HDMI out on my tv so I used the lead from HDMI 1 on my tv to HDMI out on the amp. The set up menu appears on my tv but no...
Contrary to the instructions included with most AVR's...
You don't need to take video out from the TV to the receiver. Once it gets to the TV it has found its ultimate destination.
And you don't NEEDS to GET audio FROM a TV either, unless it tunes stations from its own antenna.
Otherwise the SAT/Cable box can provide analog audio to the TV for watching lo-fi programming like news with the Onkyo OFF; and you can run digital multichannel directly to the Onkyo for its special treatment.
Running either hi-end audio or high-end video to a device that doesn't absolutely need it wastes expensive cabling and introduces a couple more connections to worry about.
http://www.retrevo.com/support/Onkyo-TX-SR605-Receivers-manual/id/2526bh742/t/2/
Feb 14, 2011 | Onkyo TX-SR605 Receiver
Tip
Onkyo TX-SR605 Manual Download
Download Onkyo TX-SR605 Manual
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
________________________________________________
RC-682M Remote Code List & Programming Guide Here.
on Apr 20, 2010 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Tip
I hope that helps.
on Apr 20, 2010 | Onkyo TX-SR605 Receiver
Onkyo sr605: needs to "warm up" before video
check your display section, is there any problem?
Jan 08, 2011 | Onkyo TX-SR605 Receiver
Tip
Onkyo TX-SR605 Remote Codes
Download Onkyo TX-SR605 Remote Codes
4 Digit Onkyo Remote Codes
Have you misplaced your Onkyo TX-SR605 Remote code list / Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Universal Remote Code List Users Guide?
I hope that helps.
Download Onkyo TX-SR605 Users Manual Here.
Tip
I hope that helps.
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
I want to control my Sony Bravia KDL-46VE5 TV with my Onkyo TX-SR605 remote controller. I cannot find the Bravia remote control code.
Sony TV codes for the Onkyo TX-SR605 are : 0000, 0650, 1100, 1167, 1300, 1505, & 1651.
Instructions for the Onkyo RC682M and more remote codes are available here. The Onkyo TX-SR605 manual is available here.
I hope that helps.
Dec 27, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR604 provides audio thru receiver but no video on Bravia LCD when satellite receiver signal is sent thru any of the Onkyo HDMI connections to tv, however if I connect up my Samsung DVD recorder...
easiest fix is to take all hdmi straight to tv. then come out of tv with optical cable to your receiver. that way what ever your watching will automatically be sent to the receiver thru optical. you even will get dolby dig. also you can have audio from your tv when you dont want to use your surround. keeps receiver on one input also.
Jul 02, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-SR605 Receiver Logo
175 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
