Kenmore Top Freezer Refrigerator Logo
Ken Mcglothlin Posted on Jan 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Removed and replaced the water filter from the base of my fridge and know I have an intermitent water hammer. Any ideas?
The intermittent hammering sound began just after removal of the old filter but was not relieved when I installed the new filter. I have verified that the filter is installed correctly. The hammering sound like a check valve lifting and reseating but does not affect the production of ice or cold water.
David Emmel
Level 2:
Sergeant:
  • Expert 295 Answers
  • Posted on Jan 06, 2018
David Emmel
Expert
Level 2:
Sergeant:
Answers
295
Questions
Helped
128452
Points
781
The new valve may not be so new. Anti-hammer water valves have around for decades, so if you replaced your old valve with a new one that hammers, take it back and request a anti-hammer valve. For some reason, hammer valves have made a return, get rid of it before it breaks a water line.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
5 Related Answers
Anonymous
  • 58 Answers
  • Posted on Oct 31, 2007
SOURCE: Kenmore Refrig with Filters water and ice dispenser- water is dripping when not in use, no flow when activated
valve needs to be replaced. it is located in the back, just follow the water line to it. to shut off water there is eaither a shutt off behind ref or in the basement. again try to fallow the water line
Anonymous
  • 958 Answers
  • Posted on Feb 18, 2008
SOURCE: no water is going onto the ice maker (Maytag Model # MZD2766gew)
the water solenoid valve is normally triggered by the ice maker itself. as it turn to harvest the ice, it should trigger the water solenoid valve to start another cycle of ice making. its either a wire harness problem that's why power is not getting to the valve or the triggering switch of the ice maker not sending power to the solenoid. i hope i was able to help you guys...
Anonymous
  • 28 Answers
  • Posted on Jul 09, 2009
SOURCE: I Purchased a used fridge
24 hours is usually enough for a fridge to come down to temperature. The ice maker may not be working properly thanks to lack of use. The solenoid valve may be plugged with something or broken inside. If the fridge is working okay and the only problem is the water delivery to the ice maker, then it's most likely just a plugged water system for the ice machine.
Lyle D. Rowh
  • 744 Answers
  • Posted on Oct 19, 2009
SOURCE: Ice maker issues - what to do next?
I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
Anonymous
  • 612 Answers
  • Posted on Dec 21, 2009
SOURCE: when water is flowing to door dispenser or ice
Sounds like your water has been off for maintenance. This will make a sound like this but the rest of the faucets would have done it also when you first ran water through them the first time. So if you have a filter on your fridge, remove it and re prime before putting back on. If not, look at the back, bottom where the water supply connects to the back. Have some one try to get water in the door while you hold your hand on the valve where the water supply connects. See if it vibrates and makes the noise. Also follow the line and see if you have two different water valves. If so do the same with it. One should be making the noise if your filter does not have air in it. Good luck.
2answers
New Sloan flushometer causing water hammer
  1. Shut off water supply to the house at the main.
  2. Open all the cold water faucets, start with the highest faucet (2nd or 3rd floor) and work to your lowest faucet (first or basement floor).
  3. Flush all the toilets in the home.
  4. Let water drain from open faucets.
    Fix Noisy Toilet ' Stop Toilet Water Hammer or Resonance ' Toilet Making Noise When Filling ' Fix Water Hammer in Toilet ' Fluidmaster
Jun 21, 2021 • Plumbing
How to Fix Hot Water Pipes Hammering/Banging?
Had a similar problem and found that the plumber who had replaced the recirculating pump had removed the plastic pipe hollders. These are spacers used to hol the pipes firmly as they pass through the wood studs. Even with only two spacers missing the hammering sound passed through the whole system. Once new spacers were installed the hammering sound stopped.
Our rinnai tankless water heater
get a hammer arrestor
https://www.bunnings.com.au/silverstorm-water-hammer-arrestor_p5070018
MSD2655HES water dispenser grinding sound
Wherever your filter is located the actual piece that you plug the filter into is either clogged or restricted it and it's called the filter head and that is what needs to be replaced. Before attempting to replace the filter head try removing your filter and see if the hammering and grinding sound goes away. If the noise goes away then you simply just need a new filter.
I changed my filter, PUR 4396841 and now it is vibrating when I stop dispensing water. Any suggestions? Do I have it installed correctly?
The vibration is a tiny bit of "water hammer." Previous to your filter change, the water flow was restricted, and therefore incapable of causing water hammer. Now that you've changed the filter, the flow is large enough to cause a little water hammer when you shut off the flow.
How to fix: shut off the flow SLOWLY. Water hammer is caused when the flow of water is shut down quickly. This is just as true with large flows (as in fire engine pump panels), as it is in itsy bitsy
filtered water lines & filter housings.
Water hammer makes a loud vibrating noise when filling
Hey- most hammer is removed by simply replacing the water valve. Have solved this way many times. Exceptions required spring suppressors on lines to faucets. Valves run about 40-60$ and are easy to install. Let me know if this info helps- have more if needed- Thanks- Ed
Kitchen Aid water dispenser makes a hammering sound when in use.
this is a pressure problem . some times caused by line size . but generaly changing the water valve will correct this problem . ****
3answers
Ibm 6400
This is a easy problem... Have any question call 972-907-9771 x311
51e9bbd.jpg ATTENTION Hammer springs and hammer tips are fragile. Do not touch the hammer springs or tips. Handle hammer springs by the
thick mounting base only. Apply pressure only to the mounting base.
NOTE: Replace a hammer spring assembly only if there is visible damage or broken parts can be seen in the assembly.
5. Remove the mounting screws from the old hammer spring assembly. (See Figure 18, page 367.)
6. Handling the hammer spring assembly by the mounting base only, gently pry the old hammer spring assembly off its
mounting pins. (See Figure 18, page 367.)
7. Inspect the hammer bank and the old hammer spring assembly:
a. If there is ink on the hammer bank mounting surface, the hammer spring assembly mounting surface, or the hammer
spring neck or tines, reinstall the old hammer spring assembly and replace the shuttle frame assembly (page 405).
b. If the old hammer spring assembly and the hammer bank are free of ink, install the new hammer spring assembly
Installation
1. Using a clean dry cloth, wipe the hammer spring mounting surface on the hammer bank. Make sure the cloth does not
leave lint on the hammer bank.
NOTE: Replace a hammer spring assembly only if there is visible damage or you see broken parts in the assembly.
2. Handling it by the mounting base only, remove the new hammer spring assembly and mounting screws from the box.
3. Handling the hammer spring assembly by the mounting base only, carefully position it on the hammer bank mounting pins.
then gently press the mounting base down against the alignment pins. (See Figure 19, page 369.)
4. Continue pressing down on the mounting base of the the new hammer spring assembly as you install the mounting screws
from the replacement kit. Using a Torx T-10 bit adapter, torque each screw to 14 inch-pounds (1.58 N•m). Tighten the
center screw(s) first. (See Figure 19, page 369.)
NOTE: Use the 1-30 inch-pound Torque Screwdriver, IBM part number 16F1661.
5. Install the hammer bank cover assembly (page 354).
6. Install the shuttle frame assembly (page 405).
7. Install the ribbon and load paper.
ATTENTION Do not attempt to adjust or “tweak” hammer springs.
8. Run an operator print test and check print quality (page 223):
a. If print quality is acceptable, return the printer to normal operation (page 339).
b. If print quality is still degraded, replace the shuttle frame assembly (page 405).
Smelly Ice and water leaking into top shelf
Does water in door dispenser taste bad? If not, Try arm and hammer fridge deoderizer. It will help to absorb fridge odors which may be clinging to water molecules in ice maker tray. Ice maker tray is open to freezer area.Water is very medium to infiltrate with odors. Try this first
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
