Computers & Internet Logo
Salama Ahmed Posted on Dec 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gp 360 test 2 failed - Motorola Computers & Internet
  • Official Brand Answer 3,100 Answers
  • Posted on Jan 20, 2015
Motorola Mobility
Level 0:
Answers
3100
Questions
Helped
684829
Points
13487
Salama
Contact Motorola Solutions Get Support or Zebra Technologies
Support Downloads. They aren't helping on FixYa yet so it is best to reach out directly.
Mark
Motorola Mobility Support
kunal singh
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Nov 20, 2018
kunal singh
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
4402
Points
90
Save hours of searching online or wasting money HELP NUMBER +1 833 272 0777on unnecessary repairs by talking to a 6YA Expert who can help you resolve this issue over the phone in a minute or two.
Why does my car **** and hesitate and has failed smog 2X is now a gross polluter ?
Because you failed to have a shop look at the data
& make the required repairs & get caught up on preventative
maintenance BEFORE you went to inspection
If you were in fact at a shop, for any reason,then they have no idea
how to test vehicle
Have you considered the motor is shot & you have leaking valves?
How to fix asm emission test failure hc( ppm) max 61 gp 274 meas 690 at 15 mph, at 25 mph max 36 gp 224 meas 804
this is easy,, it can be 1 or 2 problems.
1: CAT is dead or weak, new cats can in fact hide a crappy engine.
2: bad engine. runs like junk and does not burn all its fuel.
any good shop can find this is minutes.
what I DO (no 5gas mach)
i check for (scan tool costing me $9 whole bucks) ask)
i check for closed loop status, idling
if ok then at 15mph and then 25mph , just racing motor in neutral.
if all 3 tests pass, im good.
if any fail, i fix that. bad fueling, bad spark or whatever.
if all 3 pass, its NEW CAT TIME
easy huh? a binary answer.
bad cat, bad motor. (or both)
when i say bad motor that means,every inch of the EFI/engine system.
every drop.
1991 Honda Accord LX failed EVAP test. The ASM Emission Test Results showed Test 25mph RPM 1933, %C02 MEAS 14.60, %02 MEAS 0.22, HC (PPM) MAX 61, GP 236, MEAS 19, CO (%) MAX 0.60, GP 2.10, MEAS 0.02, NO...
Things to consider or replace...
If you are getting a Check engine Light let me know, it will make things easier to diagnose.
Catalytic Converter
Oxygen Sensor
EGR Valve
2helpful
My xbox live doesnt work
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
Xbox 360 wireless connection faiures
sure i can help, when you run "test xbox live" where do you fail in the tests?
HiWhen you attempt to access Microsoft?s Xbox Live
If you have a home network (router) try resetting it. Make sure you reset your console at the same time. You can try resetting your modem. Once you reset either give it 2 mins. to come up. Hope this works, if not contact you ISP (internet service provider).
Xbox live
2 Solutions-----
Number 1 - If your ethernet cord is going from a modem straight to your 360, then get your modem replaced by your ISP.
This will probobly be free, but if your charged, it will be a small fee.
Number 2 - If you have it going to a routerfrom a modem, then go to your 360 main screen, scroll to the far right 'System' blade, select the 4th choice 'Network Settings', and test your Xbox LIVE Connection. It will ask you to sign out. Select yes.
Results should come up (for wired router)
Network Adapter - Wired
Wireless Network - (Left Blank)
IP Address - Confirmed
DNS - Confirmed
MTU - Confirmed
ICMP - Confirmed
XBOX LIVE - Confirmed
NAT - (either moderate, opened, or strict)
If all those are the same, the problem has nothing to do with the xbox itself and you need a new router, or modem.
If results come out to be
''Network Adapter - Disconnected''
After test is run (and your 360 is connected properly to your router AND modem then you have a hardware problem. Whether the problem is in the 360 or the router/modem is easy to test.
Connect the modem directly to the 360 via ethernet. If this fixes the problem, the router is fail.
If you can get on the internet wirelessly and grounded on a computer, the 360 is busted.
Sorry it took me so long to explain that, but i hope it helps you.
Best of luck
-Erk
My 360 is not signing in to xbox live. It sais on the test connection that the ip address has failed.
  1. reset your router to factory defaults
  2. go to your 360 and reset the tests
  3. call mcrosft for help
2answers
Cannot get xbox live on test connection keeps saying fail
un-plug your router from your 360, and unplug everysingle network cable on your entire netowork. Then recconect and try again.
COMMANDO 13295
X box 360 mtu failed
First learn how to type so that people can understand what you are saying. Then post the error message that you got and exactly what it's not letting you do.
Top Motorola Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
