Trying to upload a picture to a wedding website and the number of pixels is too much and the file size too big. Trying to make it smaller.
Free picture editor download may be of use to you. You can edit the image in it in many ways like changing the size, angle, colors, etc.
It's easy to work with it and it gives no errors.
You need a picture editor to re-size the picture before uploading ..here is one I use and is free and pretty good..
http://www.mediafire.com/?mzzjojmljjz
just download ..and run it to install ..and after that click the executable ...choose not to update and select editor..In the editor left part you have to select the folder containing the picture..and select the picture itself ..after that just use the home panel ..and the re-size function ..
when you are done ..just look at the picture size written under it ..and if you are satisfied..just save the picture and select the best quality ..and a location to save it ..or it will replace the original and put it in a folder named originals.
good luck and please rate my answer cause it helps my activity on the site..Thank you for using Fixya !
