When i hook up the usb cable to the computer it says that i am hooked to the internet but when i try to get online it says that the modem is not hooked up.
the modem is a actiontec q 1000 h/w:1a fwqa01-31.00l34 computer i think is a systemax syx651M03 ser # 105478375.the modem is a actiontec q 1000 h/w:1a fwqa01-31.00l34 computer i think is a systemax syx651M03 ser # 105478375.
Are you trying to set up the router. You can do it manually without the CD. Make sure that your computer is able to go online
through the modem. If your computer is able to go online through the
modem Then you need to connect the computer to the
router and the modem to the router. open the set up page of the router and change the
settings of the router according to the ISP.
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
1. Disconnect the cable from your cable modem and connect it to one of the four on the back of the wireless router.
2 Connect a cable from the back of the cable modem to the LAN port on the wireless router.
3. disconnect the power on the cable modem for about 30 seconds.
4. reconnect the power to the cable modem and wait until the unit boots completely.
all but the activity light should be on.
5 power up the router and wait a few moments.
You should now have access on your computer that you have connected to the router. verify this by going to a web page.
6. on the laptop, open the control panel and then the network connections control panel (this assumes we are working with windows).
7. Highlight the wireless adapter by clicking on it once.
8. To the right of the icon will be a list of links. (assuming windows XP). click the one that says "view available wireless networks". Your router should be in the list. If so, highlight it and click connect at the bottom of the window.
There are several types of wireless modems available.
A PCMCIA wireless card that inserts into the laptop's PCMCIA slot.
A stand alone wireless modem that connects into the LAN port (10BaseT connector) with a network cable or a USB cable to the computer's USB port.
and
A USB wireless device (similar in size as a USB memory stick)that connects into the computer's USB port.
You need a router or a wireless router to do that. If your cable modem is wireless you can set directly via wireless network a connection with your laptop (the laptop also need a wireless card (if dont have any built in))
The connection must be done in this way
ISP ----->> Cable Modem ---->> Wireless Router o Router ----->> Computer ( 1, 2, or more)
Do a ipconfig at the command prompt and see if you are being assigned a ip from the modem. If not try rebooting the modem with the ethernet connected to modem and computer. then do ipconfig again to see if not getting internet ip, your card or modem eternet is bad. put in a new one and try again.
