Question about Rio Forge Sport Digital Media Player
Rio Forge won't use Songs on Memory Card
I used Rio Music Manager to put tracks on the memory card(s) and player. Music manager says the songs are on the Forge. The songs that are on the card(s) do not ever play or display on the Forge. I swapped cards, players, have rebooted. Do I need to wipe it out and start over? I will Never say ipod!
SOURCE:
SOURCE: Rio Forge won't turn back on
pull the battery out for 20 minutes abd that is suppose to reset it
Posted on Jan 31, 2007
SOURCE: Rio forge 512
Bend a paper clip so you can wedge it in there. leave it there for 60 seconds. take it out. pop in battery, and you're in business
Posted on Sep 14, 2007
  • 155 Answers
SOURCE: My Rio turns off mid-song
I would recommend wiping your player:
Windows only.... Please post if you are not using windows...
Open My Computer with your Rio plugged in.
Right click on your Rio carbon and click on format.
Leave the default values - if it asks you something then use your initiative.
Then click on format.
Then when it has finished formatting go to your firmware (can be downloaded from: http://www.digitalnetworksna.com/support/rio/product.asp?prodID=235).
Follow the instructions and then it should load the firmware onto your player.
When it has done then your player should (in theory!) work properly.
Hope this helps
Mowcius
Posted on May 14, 2008
  • 300 Answers
SOURCE: Forge not recognizing SD Card
the socket where card is installed may have internal loose element so its not detecting.check out the card in another device and also check another card in your device.this will confirm the fault.
Posted on Mar 06, 2009
pabloloco
  • 2335 Answers
SOURCE: my rio forge player is showing "upgrader"
When mine did this it meant the firmware inside had gotten corrupted. It started working again when I reinstalled the firmware. The official firmware is available at the official website, and wikipedia promotes an unofficial firmware that provides more features.
For either of them, plug the unit into the USB port of your computer, then run the utility to upgrade the your Forge.
(Eventually, my Forge's internal memory storage died - it still play music from card memory, but every time I turn it on I have tell it my language is english etc.)
I hope that helps.
Posted on Oct 27, 2009
Can u pls tel me how to find memory of my memory card n sim card when iam saving songs in a playlist n deleting from all songs the songs r not saved in playlist.why?
hi there!
check the memory free space from menu -- tools -- file manager and look for your memory status, if the music files are there, go to your music player, choose options -- refresh library for those new music files be added on the playlist.
Apr 07, 2011 | Nokia 6220 classic Smartphone
On my KA08 I can't use the audio player and only can listen to music through the file manager at a really high volume how can I load music into the audio player? It keeps saying the file is empty but it's...
Do not put songs into maps, only put them on your memory card, choose to load from card in audio player and now refresh the song list! it should work perfectly, just don't put the songs into maps! the onlu map you should put songs in, one by one or a bunch of'em is in the "My Music" map.
Jul 24, 2009 | Cell Phones
Mar 06, 2009 | Rio Forge Sport Digital Media Player
Sansa e260
The e260 works with microSD cards. Your 4GB card is actually a microSDHC card and won't work in the Sansa.
With a microSD card, simply put music tracks into a folder called "MUSIC". When the card is installed, the Sansa will see the additional tracks.
Jul 14, 2008 | SanDisk Sansa e260 MP3 Player
Saving songs on sd memory card
try just sending music from your pc to the memory card
Mar 27, 2008 | Motorola Mobility i870 Cellular Phone
N70 issue
Ok first,transfer all your data to memory card using fexplore or file manager then check ur phone memory if it dont work try this 1. first type dis code *#7370# then press yes and then put your security code and it will format ur phone.
WARNING: remove ur memory card and try the second solution
and all data of phone memry will b erased
Nov 27, 2007 | Nokia N70 Cellular Phone
2 probs
Press the MENU and turn it on, as soon as the word RIO shows on the screen release the power button but do not release the MENU button until it says upgrading
Plug the USB cord to it and install Rio Forge Firmware_120
Turn the mp3 off then on normally
Put the music back on your mp3 and it SHOULD be fixed. but your music will be gone..
hope this helps,
trin
Nov 19, 2007 | Rio Forge Sport Digital Media Player
Nokia n95 - music player problem
i have problem with nokia n95 music player.i have put around 30 songs in file manager but in muic player no songs are added. please give me the solution for this problem.pleaseeee.....
Nov 04, 2007 | Nokia N95 Cellular Phone
Memory Card is stupid
If it is a SD/MMC card, the usual for mp3 players, you will sometimes need to manage files differently. The memory card is sometimes listed as a separate removable drive in "My Computer" or find it in the device manager. I would suggest looking at the instructions, but you could try copying the files to a folder if you have been trying the drag and dump into the root directory.
Jan 31, 2007 | iLO MP3 Player
Memory card
Had the same problem with 64MB, but was able to use store music on 32MB and 256MB SD cards.
Oct 22, 2006 | Rio Chiba Street MP3 Player
Open Questions:
Rio Forge Sport Digital Media Player Logo
49 people viewed this question
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
