Question about Samsung Q1 Tablet PC
When I turn on the computer,I get amessage that read's Invalid partition table. What is this & how do I repair it?
    Habit-Forming:
  • 118 Answers
PC repair will fix PC issues and Driver solution will get the right drivers for your PC. I use these tools and costumers almost never contact me saying they have a problem.
Posted on Jan 02, 2012
SOURCE:
Grandson sat on table and cracked the screen. Where can we get it repaired please.
Google laptop repair in your area. I'm guessing you mean tablet instead of table?
Screens aren't that bad to do yourself depending on the model, something to think about.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Jan 19, 2016 | Tablets & eReaders
Trio STEALTH-G4 10.1 cracked screen, will start, touch screen not responding, how can i reset to see if it works or not. Is it repairable?
Contact a local electronics repair facility. If you cannot locate one in the phone book or online, stop by a table or phone sales point, and ask for recommendations.
My repaired table works as well as new.
Mar 03, 2015 | Tablets & eReaders
All I can get up on my taBLE is colored lines
Probably the screen connector or the screen is broken, goto the store where you bought it to ask if it is possible to repair. If it
is less than 2 years old, the store should repair it under the warranty.
Nov 20, 2014 | Visual Land Prestige 7 ME-107-8GB 7" 8 GB...
Mynextbook says my storage is busy what do i do
computer.howstuffworks.com/.../nextbook-tabl..
consider reading the above.
Jun 09, 2014 | Tablets & eReaders
Power Problem
I have the matsunichi 9.7 my email has amessage saying connection problem no emails has come in for 2 days. What can i do to fix the problem
Mar 05, 2014 | Matsunichi Marquis Mp977 Marquispad 9.7"...
Message missing operating system
This sounds like the main partition on your harddrive was corrupt. You will need to reformat the system.
Using the Recovery Partition:
1. Press [F9] during bootup.
2. Press [Enter] to select Windows Setup [EMS Enabled].
3. Select the language you want to recover and click
Next.
4. Read the ASUS Preload Wizard messages and click
Next.
5. Select a partition option and click
Next. Partition options:
Recover Windows to first partition only.
This option deletes only the first partition and allows you to keep other
partitions, and to create a new system partition as drive "C".
Recover Windows to entire HD.
This option deletes all partitions from your hard disk drive and creates
Recover Windows to entire HD with two partitionThis option deletes all partitions from your hard drive and creates two
new partitions "C" (25%) and "D" (75%).
6. Follow the onscreen instructions to complete the recovery
process.
Make sure to burn off your recovery DVDs as soon as you get you rsystem back up and running so that you have them in an emergency.
Feb 28, 2013 | ASUS X53U-RH11 New
80gigs partition then reformatted and displays only 31gigs
If there are files on the drive that you need to recover, then do not format it. It sounds as though the computer that you put the drive into has an issue where the bios perhaps does recognize the drive correctly. Perhaps that can be corrected by updating the bios in the computer, and trying the drive again. Or you may want to put it back into the original computer, back up the files to other media, and then put the drive in the computer and re-partition.
What does the FDISK - "DISPLAY PARTITION INFORMATION" utility report? Do you have a copy of FDISK? If the partitoins in FDISK add up correctly, then it could just be that the data is corrupt, and windows is just unable to read. If that's the case, you should try a recovery application to restore your data..
Nov 15, 2009 | Dell Tablets & eReaders
Unable to install OS on Hard drive. Error PXE-E61: Media test failure, check cable. PXE-MOF: Exiting PXE ROM. Invalid partition table
When your computer failed to boot from the disk-drive, it tried to connect to a network-accessible "boot-server" via the Ethernet adapter.
However, if there's no cable connected to the computer's Ethernet port, you will get the "check the cable" error-message.
So, your real problem is "invalid partition table", which means that the very first record on the disk-drive is either missing or corrupt.
That first record contains the "partition table", which lists the size of the hard-drive, and the size of each partition (usually only one) on the hard-drive.
So, you'll need to buy an adapter that has a USB-plug on one end, and a connector for your "SATA" or "IDE" hard-drive at the other end.
Remove the hard-drive from your computer, attach it to the connector, and plug-in the USB connector to a USB port on another computer, and then use software to delete and then reconstruct the partition table.
Or, the hard-drive is failing, and must be replaced (maybe under warranty???).
Oct 22, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
How to delete boot partition on fujitsu tablet st5030
I don't know what do you want to delete. You need at least one boot partition to boot an OS. If you need to change partition table then you can use one of many free partition programs like GParted LiveCD.
http://gparted.sourceforge.net/
It's Linux based but with GUI so if you know how to use the mouse you can deal with that.
However if you don't have an external USB CD drive you won't be able to burn the CD.
In this situation you can use unetbootin to create bootable USB key from ISO image.
Boot from CD/USB and then do whatever you want with your partitions.
Mar 13, 2009 | Fujitsu Stylistic® ST5030 (FPCM35223)...
Booting from a USB Stick
Here you go:
Download the Ubuntu Live ISO (if you dont have it already) and burn it to CD
Restart your computer (booting from the Ubuntu Live CD)
Insert a 1GB or larger USB flash drive
Open a terminal window and type sudo su
Now type fdisk -l to list available drives/partitions (note which device is your flash drive Example: /dev/sdb). Throughout this tutorial, replace all instances of x with your flash drive letter. For example, if your flash drive is sdb, replace x with b.
Type umount /dev/sdx1
Type fdisk /dev/sdx
type p to show the existing partition and d to delete it
type p again to show any remaining partitions (if partitions exist, repeat the previous step)
type n to make a new partition
type p for primary partition
type 1 to make this the first partition
hit enter to use the default 1st cylinder
type +750M to set the partition size
type a to make this partition active
type 1 to select partition 1
type t to change the partition filesystem
type 6 to select the fat16 file system
type n to make another new partition
type 2 to make this the second partition
hit enter to use the default cylinder
hit enter again to use the default last cylinder
type w to write the new partition table
Type umount /dev/sdx1 to unmount the partition
Type mkfs.vfat -F 16 -n usb /dev/sdx1 to format the first partition
"Alternately you can try mkfs.vfat -F 32 -n usb /dev/sdx1 (doesn't always work)"
Type umount /dev/sdx2 to ensure the partition is unmounted
Type mkfs.ext2 -b 4096 -L casper-rw /dev/sdx2 to format the second partition
Remove and Re-insert your flash drive
Back at the terminal, type sudo apt-get install syslinux mtools
Type syslinux -sf /dev/sdx1
Restart your computer, remove the CD and boot back into Windows
Using Windows to prepare and move the files to the USB Stick:
Create a folder named USB on your computer
Download UBconvert.zip using this link - http://www.pendrivelinux.com/downloads/UBconvert.zip
Now, extract the files to the USB folder
Move the Ubuntu  ISO downloaded earlier to the USB folder
Click fixu.bat from the USB folder (follow on screen instructions)
Move all files from the ubuntu directory to your memory stick
Reboot your computer and set your system BIOS to boot from USB-HDD or USB-ZIP. Also set the "Hard Disk Boot Priority" if necessary.
You should now be booting into Ubuntu Linux from your USB drive!
Dec 28, 2008 | Toshiba Satellite R15-829 Tablet PC
Samsung Q1 Tablet PC Logo
150 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
