SOURCE: How do you safely remove jammed nail gun?
Not sure exactly what Bostitch framer model you have, but if it is powered by compressed air, as long as you remove the air hose from the nail gun, there should be no risk of the nail gun firing while you remove the jammed nail. There should be a way to access the driver area from the top of the nail gun, even via a latch or a couple screws. Remove the top part of the driver area and that should give you access to the jammed nail, which you can remove. Use long nose pliers or something similar if the nails are really stuck.
SOURCE: will bosch nail guns operate with Paslode brand nails?
The F28WW takes 28Deg nails that are collated with wire, so your nails won't work in that gun. The N80SB is also a 28Deg nailer so your 30 Deg nails won't work in that gun either. Sorry about the bad news but it looks like your going to have to spring for new nails
SOURCE: Can I use paslode roundrive nails in a Hitachi NR90GC Gas Nailer
Yes, BUT the paslode Round drive nails and known to cause driver jamms due to the excessive paper used in the spacing of the nails.
SOURCE: oiling
Hi Andy,
If you're asking what to oil and when, here you go.
Every day before using it, oil the hammer and slide mechanism. Also put several drops into the hose connector. This extends the life of the seals. You should use a light machine oil.
Hope you find this to very helpful
Mike
SOURCE: Hitachi NV45AB coil nail gun is leaking air from
the top!! o-ring inside of thr top plate is bad you need to remove the plate /dissasemble and replace the o-ring
