During setup I get a popup window stating that Windows does not recognize the USB device (the Brother printer) and installation stops. Bought a new A/B cable at Brother Support's request and nothing. Now stating printer could defective and should return to retailer for an exchange. REALLY??? Any help is appreciative.
Hi Markaz.
you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties. Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box.
or read up more at this link.
How to Fix USB Device Not Recognized in Windows
What do I do if my USB device is not recognized?
Method 4: Reinstall USB controllers.
Error: "USB Device not recognized" when you try to access a USB ...
https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces...
Search for: What do I do if my USB device is not recognized?
or this link.
Windows does not recognize the USB device Google Search
SOURCE: Computer Won't Recognize Printer
It is not the major problem, it's the problem of OS system don't worry.
U, just reformat the harddisk again and install the fresh correct right License cd u use, to format the harddish Corrupt don't use the wrong verson or the corrupt cd. Beuz sometime the beta verson or wrong cd might not install the required program to the OS that support the hardware install in your system. fresh & ok cd u use to install OS cd. I sure that when u install fresh OS in your system there be no problem at all.
After installing the OS system and get install the mother board chipset cd which u got when u purchase the system install all the program automatically one by one& step by step. In that cd all the program will be install automatically that program will install which u system required.and then restart.the system.
After restarting the system go to device manager see all the device r install perfectly. After that u plug the printer cable with ur system the message will appear ( found new hardware) in ur screen and then fellow the instruction and install the printer program cd in ur cd drive and then continue fellow the instruction manuly.
I sure it be joyfull.
SOURCE: Windows XP will not recognize Brother HL 2040 Laser printer
you could try this: unistall the HP printer driver first, uninstall the brother driver , restart pc, load brother driver with the usb cable unplugged from printer. Software will prompt for the cable to be connected to printer
SOURCE: i keep getting
With any unresponsive USB
devices in XP it is always a good idea to try removing the device first with uninstall, plug it into a
different USB port, and then reinstall the setup software. (Preferrably using a version from the vendors home-site instead of the original CD.)
This will do two things:
SOURCE: Won't print from usb or parrallel cable
Try a different brother driver or an HP 4000 driver / pcl 5 or 6. You should get a printout.
SOURCE: Just bought a new brother HL-2170W, installed the
it is problem your operating system or driver installation
You can use basic window applications to fix this problem, However, if you are still unable to do it all by yourself. Follow this simple tutorial to fix the issuehttps://hitechweirdo.com/usb-device-not-...
I wish I was able to help you out with this.
Here is the more tips to solve this common problem on windows.https://bigfactreview.com/how-to-fix-usb...
