Thanks RR. I read on another sight how some folks figured out how to disable it with a switch when they wanted to. I'll just leave it alone and hopefully it won't give me a heart attack some day! LOLThanks RR. I read on another sight how some folks figured out how to disable it with a switch when they wanted to. I'll just leave it alone and hopefully it won't give me a heart attack some day! LOL
You can't post conmments that contain an email address.
If the Buzz is a 2011 model it will not have the zipper on the hood as it is not designed to be used with the season set (this accessory pack is for 2005-2010 models only and is no longer produced)
Hello; If you have a plasma TV, is fairly common to hear buzz noises. They can be always there or intermittent. They can get louder as the screen gets brightest. If the buzz is noticeable when you are at normal volume setting, the buzz is excessive and a PCB probably needs replacing. These buzz noises are almost never a sign of failure or safety. LCD TV's can also buzz, but the same applies. John
You need to buy the foot rest adjuster set £20 + 3.99 from Dorel UK 01842 763 281 (Mon – Fri, 8:30 am to 4:30 pm) They are the sole supplier of parts for Quinny.
The Dreami for the Freestyle 3XL is compatible with the Buzz. You will need to get a set of Buzz adapters (these are the same adapters that you would use to attach the Cabrio Fix carseat) these should cost around £18 or see if you can get them on eBay!
Hi will the graco car seat fit ? if you know that it will then you would just need the normal buzz adaptors that are used for the maxicosi carseat, they only made the one set of adaptors for the buzz/carseats
Is this buzz from the speakers?
Is this buzz from the set itself when the sound is turned down?
Is this buzz a low pitch sound?
Is this buzz a high pich sound?
Does this buzz vary in loudness with the volume control?
Does this buzz change in level from time to time?
You should post the details and the circumstances of use in order to give some idea of the conditions.
