SOURCE: Memory Card Requires Formatting
Hey B418,
Formatting will delete all your pictures on your camera or memory card. The camera might be prompting you to format because the the camera's memory is full. To avoid losing your pictures I would connect your camera to a computer, download your images to your computer first, and then format the memory.
Sincerely,
Allan
Go Ahead. Use Us.
SOURCE: Kodak Easyshare M753 Camera LCD vertical purple lines bad focus
There is no hope for the display..Plan on spending about 50 - 70 dollars for a new TFT display.
SOURCE: e-mail pictures using Kodak EasyShare software
when I send a picture, the envelope shows sending but it never goes thru to the recipient.
SOURCE: batteries in my kodak easyshare camera don't last
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
SOURCE: Delete Button on Kodak Easyshare CX7530 doesn't work
I had same problem. I opened up camera and simply move the back of the delete button around a bit to ensure the button would hit the contact when pressed. Closed the camera back up and it now works fine. I have dropped the camera a number of times I think the button and the contact became misaligned.
