LOW / NO BATTERY ALARM
The Low/No battery alarm will activate when the
power level of the battery becomes low. The display
will alternate between "b" (Battery, See figure 8) and
the cabinet temperature, the red alarm light will
become illuminated and the control panel will beep
every five seconds. To stop the audible alarm (beep),
press the "ALARM RESET" button. The red alarm
light will remain on and the display will continue to
flash until a new battery is installed. This same alarm
will activate if there is no battery installed
Hi Clair, thank you for allowing me to assist you.
When the refrigerator is
beeping or buzzing, it may be a warning sign of a possible malfunction or an
unsafe, interior temperature. To silence the buzzer, you can depress the ALARM
OFF button. However, if you have already done this, try unplugging the unit or
flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a
communication problem with the temperature control/board or wiring failure. I
would recommend connecting with a professional appliance tech for a clear-cut
diagnosis.
Hello Michael - Sounds like the temperature control was
accidently turned OFF. When this occurs the temperature control turns off the
compressor, but does not disconnect the power to the light bulb or other
electronics. Let's try activating the freezer by pressing the UP arrow until
display shows "4" or desired setting. Allow 24 hours for temperature to
stabilize. For future reference you can lock the control to keep from accidently
changing the temperature setting. I ask that you please follow up with a
comment on the post, at your convenience, to advise if further troubleshooting
is needed or if the unit's status has changed successfully. Thank you.
Aah, the favourite complaint. Basically, the display/ Main board will either need to be replaced or possibly reprogrammed. Fortunately i send my boards needing reprogramming to a friend to get done. Works extremly well after that. Careful not to let the clicking continue for long as the compressor will certainly malfunction.
Alarm will sound if the temperature of the freezer rises to unsafe levels. An indicator light will flash and continue to flash until the temperature reaches a safe level. The buzzer will also sound and will continue for 48 hours unless a safe condition exists.
It means the compartment temperatures are increased then allowed limit.Generally in some appliances the maximum temperature is indicated at the display with an alarm after the electric cutoff.If the temp is high in the compartments
