Does anyone know how to send DTMF codes with the Polycom SoundStation basic (analog) conference phone? Currently I am only able to use PULSE dialing... is there a way to change default dialing to TONE (DTMF) dialing on this old unit? Is there a dip switch inside the unit to set this behavior?
SOURCE: Conference call with a Polycom SoundStation EX
The conferencing capability to bridge 2 (or more) external stations comes from the telephone equipment/service that you have purchased. Either you are behind a PABX or Electronic KSU, which provides multiple phone service to your office, or you purchase conferencing capability from your local telephone provider (Verizon, AT&T, etc). In either case, the way to initiate a conference call would be the same as when you would have a desktop/office phone and establish a conference/bridged call to external parties. Usually this occurs by having one party on the line, flashing the disconnect button momentarily, getting a new dial tone, dialing and connecting to a second party, then flashing the disconnect button again, which signals the equipment to bridge those two calls to your station. On the SoundStation EX there is a Flash button that provides that capability of momentarily flashing the disconnect button. Try and see if that works. If not, then you will need to make arrangements to purchase the external equipment or service from your provider. If you have the PABX or electronic KSU, it may also be a configuration option that you will need to have your support person for your telephone system, activate for that station connected to the SoundStation EX. Hope that helps.
SOURCE: I have a Polycom soundstation
http://www.brennanit.com.au/UserGuides/User%20Guide%20-%20Polycom%20Soundstation2.pdf
SOURCE: Polycom Soundstation 2 disconnects during calls
this does not appear to be the sound station problem it appears u ve connected this system behind an epabx extension .if yes the extension is programmed for a call disconnection time of 15 mins.ask ur epabx programmer to change it to infinite
From bottom of connector (not clip side)
Black
Brown
Red
Orange
Yellow
Green
Blue
White
