It shows 0.00 and auto, we cannot change it at all so cannot turn oven on
SOURCE: rangemaster 110
i used the solution above worked great as i never used the clock anway . but instead of removing the whole hob i simply un screwed the front panel 5 scews. pulled the front panel out about an inch and used a pair of long nose pliers to remove the blue wires cliped them together. then just screwed the panel back took about 5 mins.
I have an Aga Rangemaster 110 which was stuck on flashing 0.00 / auto too. The solution was to press the 2 left hand buttons simultaneously and then the "+" button to set the clock.
SOURCE: their was apower cut now the clock and fan oven
where you clock is the buttons next to it, 2 have a line underneath joining to them both, hold them both down together to stop clock flashing, this will then allow your ovens to work, it's a safety feature on these ovens, and to reset clock keep both buttons held in and use the plus and minus button to set hope this helps Donna
