Belkin N1 Vision Wireless-N Wireless Router with 4-Port Switch Logo
kyle mckee Posted on Dec 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Setup cd - Belkin N1 Vision Wireless-N Wireless Router with 4-Port Switch
Level 3:
  • Belkin Master 7,733 Answers
  • Posted on Dec 19, 2011
Belkin Master
Level 3:
Answers
7733
Questions
0
Helped
1863187
Points
21487
HERE ARE THE APP DOWNLOAD http://en-us-support.belkin.com/app/answers/detail/a_id/540/kw/N1
tip
HP printer UNINSTALL using CD
<p><span><b>Resolution:</b></span><br /> <ol> <li> <span>Run the uninstaller from the SETUP.EXE driver</span> <li> <span>Delete printer from Printers folder</span></li></ol> <p><span><b>Removing printer using the SETUP.EXE driver:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver as copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <p><span><b>Deleteing Printer:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver was copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <br />
I want to istall hp deskjet 3550 to my laptop
Your HP Deskjet should have come with a setup CD.
To install it on your laptop put the CD in your laptops CD drive. The setup program may come up automatically.
Or you may have to use Windows Explorer to browse to it at 'D:\Setup.exe'. If so double click on Setup.exe to start the setup program.
When the setup program's dialog comes up select 'Install' and then follow the instructions provided.
3answers
Error on startup: Windows could not start because the followiing file is missing or corrupt: \windows\system32\config\system. You can attempt to repair this file by starting windoes setup using the...
Do not press r at the first startup screen, allow it to continue all the way through. When it gets to the point where its going to reinstall it should say searching for previous windows installations and ask you if you wish to repair it. Click yes and it will do just that
I would like to setup wireless printing with my hp h470 on my |NETBOOK. because it is a netbook, i can't use the cd that came with the printer to setup wireless. how do i setup wireless printing using my...
If you have a USB memory stick (Flash Drive) you can copy the contents of the CD to that and then run the setup program from there. If you don't have a PC with a CD drive you could ask a friend/colleague to copy the cd onto the stick for you.
18helpful
2answers
Setup cannot find the required setup controller file. Either there was a network error, an error reading from the CD, DVD, or other installation media, or a problem with the package you downloaded.
6helpful
2answers
Install Works 9 from CD? How? Microsoft Works9
Insert the cd into the cd drive, the setup should come up automatically, if it doesnt come up then open my computer, double click on the cd drive, if the setup still doesn't come up, right click on the drive and click on open, if it didn't open automatically. Then look for the setup file and double click on it to start the setup.
if it still doesn't install try the cd on another computer to confirm if the cd is working. if it works on another computer then the issue is with your cd/dvd drive, if it doesn't work on other computers aswell then the cd is the problem.
4helpful
Setup cd
You can setup the router even without a CD setup, if you know how to access the router setup page where you can do the configuration that will do the setup, But if you're not familiar with it better contact Linksys tech support so they can walk you through with the process on how to set it up without the CD this is the number 800-3267114.
Hope that helps.............
Setup problem
when u say setup do u mean bios setup or windows setup.if windows setup u have os disk in cd.if not , in bios choose save and exit if no joy have hd problem maybe need to reinstall os.
2answers
No sound
check on the cd and see if there is more than one setup file for your sound. If it is the motherboard setup cd then quite often there is more than one kind of sound shipped with the boards and all the drivers for various units are on the same cd.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
