Question about Canon PIXMA MP530 All-In-One InkJet Printer
Want to set up fax capability with FIOS. Right now, fax answers before I get a chance to pick up. Also, how can I have it work in conjunction with Voice Mail, if I can?
Had been using Vonage, which could not send signals to fax capabiity. Now I've switched to Verizon's FIOS for a line with Voice Mail and the fax picks up too quickly. Also, is it an "either.or" proposition that I chose a fax capability or voice mail. That is utilize Voice Mail by default and plug in when I expect a fax or wish to send a fax? Thanks!
4 Suggested Answers
SOURCE:
SOURCE: Canon imageCLASS® MF4150 All-In-One picks up all calls on our second line.
I got in touch with the manufacturer tech support and found there was no way around it. Thanks for considering my issue though :)
Posted on Sep 13, 2008
  • 29 Answers
SOURCE: can't send or receive faxes
it's most likely the compression on the phone line or you need to set up your fax machine for proper receive mode.
Contact your phone service provider to see if they support faxes.
(Faxes cannot handle nearly as much compression as standard voice)
Posted on Jun 09, 2010
Joed911
  • 4338 Answers
SOURCE: I don't use an answering machine. My phone has
You need to set your phone to pick up later than the fax machine. set it to pick up on the 4th or 5th ring, set the fax to pick up at 2 or 3. Better yet, get a distintive ring # set up by your phone co. then the fax will only recognize that ring.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Dec 30, 2010
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
How to receive a fax
  1. Connect the multi-function printer to a phone line. Most printers with fax capability have more than one phone jack, so make sure you are plugged into the right one.
  2. Turn the printer on and access the start-up menu. Pick an answering mode based on your expected usage of the fax capabilities of your machine (see the next steps for more information about this).
  3. Put the printer in manual mode if you expect little fax traffic. The manual mode usually requires you to pick up every call that comes to the machine. If you hear the signal for a fax, you push the start button and hang up.
  4. Choose the automatic mode if you expect a lot of faxes or have a dedicated fax line. In automatic mode, the printer listens to incoming calls and determines whether they are faxes or voice calls. Voice calls get sent on to your phone, and faxes are picked up by the printer.
  5. Select the number of rings you want your multi-function printer to give you before dropping a call. If you are using the manual mode you may want to go with four or more rings. Two rings should be sufficient in the automatic mode.
  6. Load paper into the paper tray. Check on the paper level frequently if you receive a lot of faxes.
  7. Set the desired print quality, and you are ready to receive faxes.
Mar 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How to receive fax
Instructions Things You'll Need:
  • Phone line
  • Multi-function printer
  1. Step 1 Connect the multi-function printer to a phone line. Most printers with fax capability have more than one phone jack, so make sure you are plugged into the right one.
  2. Step 2 Turn the printer on and access the start-up menu. Pick an answering mode based on your expected usage of the fax capabilities of your machine (see the next steps for more information about this).
  3. Step 3 Put the printer in manual mode if you expect little fax traffic. The manual mode usually requires you to pick up every call that comes to the machine. If you hear the signal for a fax, you push the start button and hang up.
  4. Step 4 Choose the automatic mode if you expect a lot of faxes or have a dedicated fax line. In automatic mode, the printer listens to incoming calls and determines whether they are faxes or voice calls. Voice calls get sent on to your phone, and faxes are picked up by the printer.
  5. Step 5 Select the number of rings you want your multi-function printer to give you before dropping a call. If you are using the manual mode you may want to go with four or more rings. Two rings should be sufficient in the automatic mode.
  6. Step 6 Load paper into the paper tray. Check on the paper level frequently if you receive a lot of faxes.
  7. Step 7 Set the desired print quality, and you are ready to receive faxes.
You should be all set now to receive faxes.
Aug 06, 2010 | HP Officejet 4355 All-In-One InkJet...
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not...
Set your answering machine to pick up after four rings2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Nov 13, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Canot recieve fax
Try these settings ::>>
1.) Press Setup
2.) Select Fax Settings, then press OK
3.) Select Communication, then press OK
< under communication try these settings >
> DRD should be all
> ECM should be off
> V.34 should be off
> Rings to answer ( if you have an answering machine?
or a voice mail service either virtual or physical.,
check how many rings does it have before it picks up )
set your printers rings to answer about 2 rings higher than these devices.
> Auto answer on the control Panel of the printer should be on / enabled
Note ::>> If still cannot receive a fax? try to disconnect your voice mail or
answering machine to the line to Isolate Issue whether printer cannot receive
a fax or the said devices is having an issue with the printers fax
receiving capability.
Mar 28, 2009 | Epson Stylus CX9400 Photo Printer
Not receiving faxes
make sure your answering machine is plugged in to the "EXT" jack on fax machine, and your main line plugged into "line". try setting fax rings to 1 or 2. set your answering machine to 4. your fax should intercept the call and if it hears the fax tone, will receive the fax. if it doesn't hear the fax tone, it should forward the call to your answering m/c.
hth,
razors
Jan 03, 2009 | Brother IntelliFax-2820 Laser Fax
Always get a busy signel on fax and cannot get fax through
Check to see if there's an answering machine picking up before the fax machine gets a chance to answer. The person receiving the fax might need to temporarily disable their answering machine first.
Nov 12, 2008 | Office Equipment & Supplies
Epson Aculaser CX11NF won't receive faxes
Change your incoming mode from "autoswitching" to "TAM" (TAM is short for telephone answering machine" Press the "Setup" button on the control panel Use down arrow twice to select "FAX SETTINGS" Press the right arrow once The FAX SETTINGS menu appears Press the down arrow twice to select RECEPTION SETTINGS Press the right arrow once Press the down arrow unit INCOMING MODE appears in display Press the right arrow once Press the down arrow until TAM appears in display Press the right arrow once. That should do it for you If I got lost somewhere, it is in your Operator's manual - look in the index for TAM Hope it helped Ed
May 22, 2007 | Epson ACULASER CX11NF All-In-One Printer
Hooking up a fax machine on home telephone line
Well... the problem is that you are running two machines on one line. ONE of them has to take predominance. Both machines should have settings for "number of rings to answer at". It sounds like you currently have the fax set to less than the answering machine, so the fax picks up after two rings, while your answering machine might be set to more, which it never gets to, because the fax answered the call already(It doesn't matter if you answer the phone, or the fax picks up, once the line is open, the answering machine is taken out of the equation). Even if you set the answering machine to answer first, you're then taking the fax service out of the loop. I'm not sure how you're going to juggle that, since both types of machines each need control over the line to work properly. That's why we (business machine folk) always recommend a dedicated line for fax service.
Jan 23, 2007 | Canon FAXPHONE L170 Plain Paper Laser
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
81 people viewed this question
Clive
Clive
old marine
old marine
Ekse
