Question about Buck Scrubbing Bubbles& Automatic Shower Cleaner - 2 Pack
PUR faucet mount water filter doesn't light up at all
I put a new Filter cartridge in the mount, but the indicator light did not light up. I opened it and the red light stayed on constantly for a while. When I put it back on, again it did not light up.
Bought a new faucet and my pur filter no longer fits. It won’t snap on any more.
The Pur filter was designed to fit a "standard" faucet even though the standard varies widely. There is not much hope of finding an adapter that will work.
Apr 17, 2018 | Plumbing
How do you fix the light in a Pur faucet filter
It could be mineralized, try soaking it in vinegar or scale remover.
Mar 03, 2017 | Refrigerators
Low Water pressure from the unfiltered spout on the Pur wat?r filter rf-9999. Plenty of pressure in the line.
Check out the nozzle screen for clogging. And if that does not do it then the cartridge inside your faucet is not operating properly. And those cartridges can usually be replaced. If faucet is a Moen it has a lifetime warranty and all you do is call them and they send to your home a brand new replacement cartridge. Do U have a Moen?
Mar 04, 2016 | Plumbing
Why is my Pur faucet filter so slow? It was not before
You either need to clean the the screen filters prior to as they may be blocked. The filter cartridge itself my need to be changed as you don't say how old it is.
Aug 29, 2013 | PUR 3-Stage Vertical Faucet Mount Gray...
PUR Faucet Mount Water Filter indicator light does not work
Take it loose from the faucet and flip the lever down on the filter in the on position. Take the cap off and remove the filter. Blow hard through it. You should hear a whirling noise of a gear, like a windmill. If not, I use a water dental pic to pulsate into it and clean it out. This is what makes the light work and when flow goes down, the light changes color. It's all mechanical. No battery. Just free up the gear so it turns freely to work the light. If standing in front of a mirror, you can actually see the light come on. PUR doesn't tell you this because they want you to purchase another one.
Dec 17, 2011 | Buck Plumbing
Which glue to reattach chromed plastic to plastic?
Use old fashioned model cement. Not the child safe type. The old type will melt the styrene to the styrene. The new stuff only fills the gap but never really makes a good bond.
Mar 10, 2009 | PUR (FM-9500) Air Purifier
Red led light on constantly
electronic circuit needs replacement
Feb 01, 2009 | PUR (FM-9500) Air Purifier
Can't remove the filter from my Pur Flavor Options faucet mount water filter
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Aug 04, 2008 | PUR (FM-9500) Air Purifier
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Nov 18, 2007 | PUR (FM-9500) Air Purifier
Buck Scrubbing Bubbles& Automatic Shower Cleaner  - 2 Pack Logo
692 people viewed this question
Top Buck Home Experts
Donni Steen
Gene Haynes
Steve Allison
Steve Allison
Are you a Buck Home Expert? Answer questions, earn points and help others
