Question about Dremel Mini - Mite Cordless Rotary Tool
Trouble Changing Attachment
I am trying to remove the collet that the Minimite originally came with and attach the sanding drum instead....but I cannot loosen the collet to remove it. I tried pressing down on the red button and loosening the collet by hand (as the directions said), but still cannot loosen it. Can anybody help?
  • kayachka Oct 25, 2008
    I tried doing that, but when I hold the button down all the way, the collet locks up and will not turn at all. When I hold the button down half way, the collect will turn but doesn't loosen (no matter how many times I turn it). I think I may have a defective Minimite....but thanks anyway!
    New Friend:
    Problem Solver:
  • 7 Answers
Have you tried using the little spanner that comes with the tool?
Posted on Sep 03, 2014
    Champion:
  • 242 Answers
Looking down on the collet end of the dremel, push red button and take pliers and turn locking nut in a counter-clockwise direction.
Posted on Oct 24, 2008
SOURCE:
I need someone to tell me how to remove the entire attachment bit from the tool
dremel have a collet adaptor available to allow interchange of bits. They are available from dremel or hardware stores.
Feb 07, 2013 | Dremel Variable - Speed Multipro Rotary...
I need a manual for Ryobi HT20VSK
The multi tool has no "chuck", it uses collets to fix the bits to the tool. Once the knurled cap is loosened or removed, the collet and bit can be removed. If the cap has been overtightened or left in the tool for an extended time, you can remove it by gripping the shank with pliers or vise grip and turn it to release the collet and bit.
Dec 29, 2011 | Ryobi Drills
I can't get the small sanding disc out of the tool.
Undo the chuck nut and then knock the spindle shaft of the sanding disc in lightly. This should release the collet's grip on the shaft. If the shaft has been pushed all the way into the chuck, remove the collets and nut and try separate the collet segments to release it from the shaft.
Aug 11, 2011 | Craftsman Single Speed Rotary Tool
Can't unscrew collet
it is possible that you stripped lock mechanism on the collet, for the beginning, never, ever, use wrench to tighten the collet! just hand tied, if it slips, tight it bit more, but with hands only.
i never used wrench on the collet and never have any trouble with any of my dremels.
to close, just hold firmly in one hand pressing locket button, tighten up with other hand, to undo, reverse procedure.
if you find bit is too lose, then you have collet inserts, find that one which hold bit firmly and use it on this particular bit. standard collet is 1/8" (3.175mm), but in the set there are collets from 0.0394'' (1mm) to 0.177" (4.5mm). do not use wrench...
just inspect now if thread is not stripped, on spindle and on collar, if locket still hold, if these are damaged, you need to change damaged part. and follow the advice :-)
if you find this advice useful, pleasae do not hesitate leave your remark and vote4 for me, thanx!
Jul 31, 2010 | Dremel 400 Series Xpr Rotary Tool Kit with...
Collet on Freud router won't release bit
a new collet won't hurt, but you may try sanding down the inside of your existing collet with 120 - 180 grit sandpaper. also, buff down the router bits
any condensation or moisture that may have gotten on these items can cause almost invisible oxidation that you can remove easily by sanding. DO NOT USE WD40!!!
Dec 05, 2009 | Freud FT2000E 3 Router
I cannot get the chuck to tighten the collet
sounds like u are using the wrong collet in the end of dremel the normally have a couple of different collets try changing it for a tighter one also make sure its in the right way
May 29, 2009 | Dremel 750 02 Minimite Cordless Rotary...
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
Trying to figure out how to change attachment for a black and decker rtx 3 speed rotary rool
The black and decker rtx uses the Flip-Lock spindle lock system for attachment changes. At the top of the tool there is a small rubber lever just above the on-off switch. Flip the lever down, and losen the grey collar surrounding the collet. Remove the collar and change the attachment. Then tighten the grey collar, and flip the lever back up. That's all there is to it!
Jun 18, 2008 | Computers & Internet
I can't get the head to open to take out the bit
Unplug it, then while pushing in the little silver button near the head use a wrench on the hex nut and turn counter clockwise about a 1/2 turn. Push the bit in, then pull it out (that releases the little fingers that hold it).
The silver button locks the head so it won't spin while you are changing bits. Always be sure it is released before plugging in or turning on the power.
Feb 19, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Mini - Mite Cordless Rotary Tool Logo
389 people viewed this question
Top Dremel Tools & Hardware - Others Experts
cluffermon
Level 1 Expert
Mike
Van Allen II
Van Allen II
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
