I have a copier that went a little bit over the 100k with the original parts about 170k.
I cleaned it and after i changed the developer, developer sensor , drum
, cleaning blade for drum and fuser it gets stuck at L-detect with 0004
and if i start it up it gives me an error like F-26-3.
I tried to reopen the drum and check if there are any other visible problems but there was nothing that seem to be bad in it.
If anyone has any kind of ideas please feel free and share them.
Thank you all.
The copier has those exact parts in it , the blade seems to be in perfect shape(is new also).
The problem is that before I changed the developer and the drum, blade and the fuser the copier went into a f-26-3 because i started it up without the fuser, I know how can you forget but in the same time i do tech support so you can imagine that my life is not that easy. With the old and the new fuser i get the same type of errrors
Thank you for your answer, I type it in and it didn' t show up on my other post
when i switch on my konica 7022 photocopier,it gives me an error message that i should adjust L detect.
