I have new software on my Mitsubishi wd 62525, I do what directions say but does NOT download to tv, my version is 4.01, mitsubishi sent me a card with new software, directions, disconnect power from wall, put card in slot #3 plug power cord back in, and is supposed to automatically boot, when finished the tv will turn on automatically, I have done this, green light flashes fast but does not boot up, I take out card turn on tv go to see if upgrade worked at all, and nothing, still same firmware, is there another way? if anybody has been through this and was successful please respond thank you Jesse d
SOURCE: Mitsubishi WD-62525 DLP has no picture
the lamp went out in our wd-62525. I replaced it and cleaned the filter, now it makes a strange noise every few minutes and the picture gets distorted, then it's fine.We have had this set for only 16 months and have had to replace the mother board. What do you think the problem may be?
SOURCE: mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
SOURCE: Can't connect the wii to Mitsubishi WD62525
usinng the av cable (1 yellow, 1 red, 1 white), on the back of the set
plug them into input one. input one is actually the third set of jacks down on the terminal board. the first is audio out. the second is monitor out (it has video) and the third is input one.if input one does not show on your device menu the you will have to add it with the netcommand menu.
SOURCE: im getting error code 34 on my mitsubishi tv wd
Heres a link to the kit which will repair that issue. The kit contains the replacement capacitors and the step by step instructions with pictures. Heres the link to the proper kit.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
SOURCE: cannot turn tv on
Check power supplly make sure its not the fault in wht this will not turn on.
Unplug tv from wall wait 30 secounds and plug back in.
If that does not work you will need to have someone look at the powersupply.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
