Open the side door by pressing its lever outward.At left and right sides of transfer belt you will see screws.Two screws, one at left side and one at right side.open the screws and pull out the transfer unit.Push little upward and then outward.Now again do the same process while fitting,Fix the transfer unit and after fixing tighten the screws.
The error message under that title is "Have the image transfer belt replaced soon." It's a new unit, but resists doing the Gradation Adjust. Tried returning the old belt (which was working before the replacement) and error message remains, so apparently the problem is not with the new belt.
System Error Clear (System 1 -> Initialization) gives "Result: OK" but has no effect; the problem remains after machine restart. However, it does NOT at any time give L-5 error (Transfer belt unit accumulated rotation time excess warning), just continues to say "replace image transfer belt unit", and will not allow anything else to proceed. What am I missing? (Transfer belt clutch malfunction?
Paper transfer unit contact error
The paper transfer unit contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates.
?? Defective paper transfer unit contact sensor
?? Defective paper transfer unit contact motor
1. Check or replace the harness.
2. Replace the image transfer belt unit or paper transfer unit.
3. Replace the HVPS-TTS board.
2002 GMC Yukon
2002 GMC Yukon
2004 TRANSMISSION Transfer Case - NVG 149-NP (One Speed Automatic) - SUV
TRANSFER CASE NO FRONT DRIVE
Transfer Case No Front Drive
Cause
Correction
DEFINITION: The transfer case is not delivering engine torque to the front propeller shaft.
Review the Symptoms - Transfer Case and perform the necessary inspections.
Viscous coupling faulty 1. Inspect the transfer case fluid for being black. If the fluid is
black, it is most likely caused by a viscous coupling failure.
2. Test for a faulty viscous coupling. Refer to Transfer Case
Description and Operation.
3. Disassemble the transfer case. Refer to Transfer Case
Disassemble in Transfer Case - NVG 149-NP3 Unit Repair.
4. Inspect the viscous coupling for a bulged cover. Refer to
Cleaning and Inspection in Transfer Case - NVG 149-NP3 Unit
Repair.
5. Replace the viscous coupling if it is faulty. Refer to Transfer
Case Assemble in Transfer Case - NVG 149-NP3 Unit Repair.
Planetary carrier faulty 1. Disassemble the transfer case. Refer to Transfer Case
2. Inspect for faulty planetary carrier components. Refer to
Repair.
3. Replace any faulty planetary carrier components. Refer to
Transfer Case Assemble in Transfer Case - NVG 149-NP3 Unit
Repair.
