Hi
i have problem with sharp microwave oven R 959M Whem im cooking on grill function,at the begginning everything is okay,but later (after 3 mins) microvawe stopping and it showing text TURN OVER RE ARRANGE AND SIELD IF NECESSARY!And doesnt matter it is ful or not,so i am confused now,what to do???
Probably a bad bottom door switch or its mount. See help file here.
SOURCE: Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
SOURCE: faulty microwave function on the SHARP R-957 model (900watt)
This
is a problem in one of the damper-related components, most likely the
switch, but it may also be the motor or the damper door.
The
damper is a door inside that opens or closes depending on cooking mode.
If the controller senses that the door is not in the right position, it
will shut down the cook cycle.
Sharp models stop after
59 seconds.
See the attached sample
photo for a typical damper assembly.
Info on ordering Sharp
UK parts / spares is here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
William E. Miller
[email protected]
http://www.microwavedisplay.com
SOURCE: instructions for Sharp R953 900wt jet convection grill microwave
Info on ordering SharpUK parts / spares is here.
We'rehappy to help you with free advice and we'd appreciate yourthoughtful rating of our answer.
SOURCE: I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
We're
SOURCE: manual for sharp grill 2 convection oven
where is the fuse at on the sharp grill 2 convection
The turntable light is still working as well as the Oven and Grill however the microwave does not heat up any food.
I bought a Sharp Microwave Oven with Sensor, Grill and Convention functions, R-967(SL)M, a few years ago in London, United Kingdom. Problem: Now, each time the timer counts down to 1 second (for example, 1 sec. or 2 mins. 1 sec. or XX mins 1 sec.), the heating function just stop as long as the timer shows 1 second. In addition, I relocated to Hong Kong and the local Sharp customer service refused to provide any repair service (even if paying!) since I did not buy the product model in Hong Kong! The warranty period has ended, hence there is not an issue with warranty service. Appreciate if any expert(s) out there could kindly provide assistance or at least offer a direction/suggestion which I could pursue to get the appliance back to working again. Thank you!
