My phone doesn't find the device (Jabra bt3030, version unknown) even when it's solid blue and i search for a bluetooth device on my phone(HTC Desire HD, Andriod 2.3.5).It have worked before, but never after i updated my phone. could it be that i need to update the firmware on the device? in that case, where can i find the latest firmware?
SOURCE: Jabra BT3030 Device in Discoverable Mode?
Read the users manual(google is your friend)
But in case they drop support soon, turn the beastie on, press and hold the Vol+ and Answer Call buttons till the "on" light goes solid. You're now in discover mode.
SOURCE: my lg prime will not pair with my jabra bt3030
you have to make sure your blue tooth device is in discovery mode most devices you just hold the power button for 6 to 10 seconds when turning it on,if you have it in discovery mode they will pair and you will be asked for a pin or pairing code ,most blue tooth manufactures use a 4 digit code they are as follows 0000,1234,1111 or 9999 i hope this helps
SOURCE: I'm not able to pair
You must specify what type of phone, make and model. there are some phones that just will not sync with some headsets. I have actually owned a couple of phones that would not sync with my Jabra headset.
SOURCE: NEED NUMERIC PASSKEY FOR JABRA BT3030
According to the mfg. website, the default passkey is 0000.
Thanks.
