ICAN SEND FAXES OUT BUT I CAN,T RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line? If you have an answering machine connected to the same
line as the fax, set the answering machine to answer incoming calls before the
printer does. Increase the number of rings by a factor of 3 over the answering
machine. For example, if the answering machine is set to pick up on 4 rings,
set the printer to pick up on 7 rings. If you have a voicemail feature in the same line as the
fax, you may subscribe from your phone service provider for a distinctive ring
pattern feature. You can program your printer to have a distinctive ring
pattern and phone number for incoming faxes.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
