Exercise & Fitness Logo
kara schoen Posted on Dec 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The treadmill is in the folded position. How do I get it to go down?
ernesto cuadra
Level 3:
Top Expert:
  • Nordic Track Master 12,223 Answers
  • Posted on Dec 19, 2011
ernesto cuadra
Nordic Track Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4081226
Points
34431
Http://www.youtube.com/watch?v=kDNegYEnrSc
See the video how to fold and unfold.
Please take if the pin is bend, you must use some hammer.
Sincerely. Merry Christmas.
ernesto cuadra
managua, nicaragua. c.a
Treadmill deck will not fold in the storage position
HOW TO FOLD THE TREADMILL FOR STORAGEBefore folding the treadmill, adjust the incline to the lowest position. If this is not done, the treadmill may become permanently damaged. Remove the key and unplugthe power cord. CAUTION: You must be able to safely lift45 pounds (20 kg) to raise, lower, or move the treadmill. 1. Hold the metal frame firmly in the location shown bythe arrow at the right. CAUTION: To decrease the possibility of injury, do not lift the frame by the plastic footrails. To raise the frame, bend your legs, keep yourback straight, and lift with your legs. Raise the frameabout halfway to the vertical position. 2. Raise the frame until the latch knob locks into the storageposition. Make sure that the latch knob is locked in thestorage position.To protect the floor or carpet from damage, place amat under the treadmill. Keep the treadmill out of direct sunlight. Do not leave the treadmill in the storage
position in temperatures above 85 Fahrenheit.
http://www.treadmilldoctor.com/?utm_source=fixya&utm_medium=CPC&utm_campaign=Mendi
How do I get my proform 810 tr to fold down?
http://www.youtube.com/watch?v=hHeYb6CoK4c please see the video for to see how to fold or unfold.
and then Read your user manual. if you do not have, please go to www. proform. com
then customer service and the section parts & manual, you give the model and serial and you download for free. Good Idea !
sincerely.
I cant get my c2050 out of the doorway.ive tryed getting it trhue the dooeway no angle will work. i cant find anything to detach to take it apart. any suggestions?
A) HOW TO LOWER THE TREADMILL FOR USE
1. Refer to drawing 2 above. Hold the upper end of the treadmill with your right hand as shown. Using your left
hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock
knob. Note: You may need to push the handrail to the side slightly.
2. Refer to drawing 1 above. Hold the treadmill firmly with both hands, and lower the treadmill
Watch thsi video:
http://www.youtube.com/watch?v=kDNegYEnrSc
lowest position. If this is not done, the treadmill may be permanently
damaged. Remove the key and unplug the power
cord.
1. Hold the treadmill with your hands in the locations shown
at the right.
Raise the treadmill about halfway
2. Move your right hand to the position shown and hold the
How to fold my afg 5.0 treadmill for storagae
Dear Sir: Hello , i hope everythign is o.k
Please do the following:
FOLDING Firmly grasp the back end of the treadmill. Carefully lift the end of the treadmill deck to the upright position until the foot lock latch engages and securely locks the deck into position. Make sure the deck is securely latched before letting go. To unfold, firmly grasp the back end of the treadmill. Gently press down on the foot lock latch with your foot until the lock latch disengages. Carefully lower the deck to the ground. NOTE: on some models the foot lock latch might be on the right hand side. NOTE: when folding the Horizon Fitness Treadmill the console assembly will tilt away from you, but will return when fully folded in the upright position. Please allow two additional feet from wall when folding.
Thank you in advance, sincerely. Blessing.
If you need additional help, please contact me.
e.cuadra Managua, Nicaragua C.A.
1helpful
I can't fold my treadmill back up. Instead of folding upright at the 12 o'clock position it is tilted to the 11 o'clock position. Any ideas why it won't go all the way upright?
1) SEE IF SOMETHING IS PENDING between the folding section
2) Your Pin is little bend.
3) the receiver where the pin is coming is not adjusted.
sincerely.
How do you get the running deck down?
If you are saying that the deck is in the folded position and will not fold down then pull the pin on the left side of the deck. If the pin is stuck then try and plug in the treadmill insert the safety key and push the down incline button on the console. This should make it so that the pin will un-jam.
How to make the base lock in place.
Before folding the treadmill, adjust the incline to the lowest position. If you do not do this, you may damage the treadmill when you fold it. Remove the key and unplug the power cord. CAUTION: You must be able to safely lift 45lbs. (20 kg) to raise, lower, or move the treadmill.Raise the frame until the latch knob locks into the storage
position. Make sure that the latch knob is locked in the storage position.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
