My Lg shine is blocked because i wuz dumb enough to keep tying puk codes can any one possibly tell me how to unblocked? i would really appreciate it.
To get the PUK code for the LG Shine, you need to call 1-800-331-0500 which is customer support. Tell them you have a lg shine and need the puk code. They will ask your phone number with area code, the last 4 digits of the ss# on that account.
They will supplie the code to you and your phone will be free. If you enter in the wrong code too many times, You'll end up having to buy a New SIM Card!
Why does everyone say you call or go to the store? you log on to att.com and log in then go to my phone/device and hit unlock sim card. =)
Once its blocked that means the sim is blocked completley. it really doesnt have anything to do with the phone itself. the only way u can fix it is by getting a new sim card because it is now trash.
Don't try to enter a PUK code without knowing the right one. You need to call your service provider to get this code. It can be as many as 8 digits, and it is random. If you enter too many wrong codes, you can permanently damage the device.
Ok first take out your sim them on the back theres should be 4 didgits remember those didgits then put i back in turn on your phone then put those 4 didgits in then you should have it
ON MY LG SHINE PHONE IT HAS PUK BLOCKED WHAT IS THIS AND HOW CAN I FIX IT??? PLEASE HELP !!!!!!!!!!!!!!!!!!!!!
Take it to a nearby at&t store.
How to unlock my puk number
I'm just a 10 year old but buy a new sim card
But what if it won't let you enter any numbers into your phone? does that mean i have to get a new sims card?
This happened to me, my whole PUK got blocked. So The best solution is take it to any good cellular and ask them if they can get you a sim with the same no.
Dont Worry, just call your service provider and ask for the PUK code. The same thing happened to me, and I just called and problem solved.
Mine has the same problem
but after i got blocked out of my phone i read my handbook
and it says that the default puk code is 0000
i dont know if it is cause my phone wont let me do anything but...
hope it helped
Puk blocked pls help
Uhm, I called customer service and it gave me the code. :]
This is what happened to me...but I tried entering to many PUK codes....so now do I have to do something about it...and also I never had a sim card in my phone...its an LG Xenon Touch screen HSPA.? what do I do now?
SOURCE: lg shine puk blocked how do i unlock!?
hey,
time to get a new sim card, call your service provider or if you used a prepaid card buy a new prepaid card.
you can return the card to your service provider or cut it to parts and throw away.
noting wrong with the phone and it will work perfectly with any other sim card.
Thanks,
Ekse
Update Ur phone software (Take a back up if possible through PC)
Hi
The puk code is sim card spesific it comes with the sim card when you get it or you can get it by calling your phone service provider of the sim card to get the puk code.
if you have entered the puk code wrong too many times you will make the sim card useless and you will have to contact your phone service provider for a new sim card, it will probably cost.
The easiest way to get the PUK code is to call your service
provider, such as T-Mobile or Verizon. They need to verify your cell
phone number and your IMEI number and they will provide you with the
PUK code.
Hope this helps,
Joe
SOURCE: My Lg shine is blocked because i wuz dumb enough
wat you use sim card or monthly bill if you use a sim you must changes it if you are using a monthly bill you must call to your operetor
My LG Shine says PUK Blocked I need a way to unblock it... and hopefully be able to keep everything that was on my sim
lg cu720 imei 011487008240703
My LG Shine says 'PUK blocked' and i do not no wat to do?
my lg shine is puk blocked because i kept on pressing puk codes how do i unlock it
my lg foneis block and how do i unblock it
please help me unlock my LG KE970 fone, the screen appears wen i slide it open but cant access the keypad or buttons
Someone returned my phone and when i turned it on it said "PUK Blocked." THe only two options i had were to turn my phone off our call 911 or 112
my phone is locked and i dont know how to unlock it
i entered the wrong pin and the wrong puk code and i could not get it unlocked
i entered the wrong pin code and some other stuff and now its puk locked! please help!!!!!!
OH MY, i'm stupid to keep trying the PIN code. -_-
Now i need the PUK code too.
My phone locked.
Mines Keeps on asking me for a puk code but the code isnt on my box :-S can anyone please help me ?
I have had the same issue. I guess after the tenth time you are blocked for good. Only after did I realize that you can go onto yu account and get the PUK code under phone/device...
my phone locked too
i reall ned help, it wont let me do anything!!!!
please help!
its blocked
my phone is locked
i accidentally locked my phone....now when i turn it on, it says "enter PUK code
Dam I have the same problem too I was stuped to lock my self out and my cell phone is useless now. I can't enter in any code because I was entering the number to the PUK code 7 times and I got locked out. so I need help to unlock it. Or I might have to get a new sim card(it sucks) I"ll never make that mistak again if I get a new sim card T.T. And mine is just an LG shine.
it says enter puk code
I didn't know my puk or watever code so I kept trying and know I'm blocked out! Please help me!
i was trying to find the pin code and i did it so many times and then the puk thing came up and i did that so many times and now it wont let me do anything except call 911
I try the puk code too many time in now its block
Same exact problem. Annoying because you never actually try to hack into the phone, you just try to set a code, and just getting it wrong 3 times, then 8 times, screws you over for some reason.
pointless to block phone out like that, its not like anyone was trying to hack into a phone lol.
it says punk block and it doesnt have a code that u can put in what do i do
my Lg shine has the puk block on it. It wont let me do anything but call 911.
what is a puk code?
so annoying. i never even set a puk code, so how did it block me out. i was just trying to change my security code and now im screwed. im calling att
puk is blocked
puk blocked - how do i unlock it with knowing the code?
I HAVE AN PUK BLOCK AND I NEED THE CODE TO GET IT UNLOCKED HELP
I have the same problem too! stupid phones!
my phone is lock to!!!!
my phone doesnt have a thing where i type the code.
it only has a picture of a sims card with an arrow pointing to the right and emergency numbers like 911 and 112.
i thought it was because i turned it off then turned it on again.
anyone with he same problem?
i kept putting the puk code on and it blocked me out of my phone wut do i do!!!!!!
Alright, So tell me exactly what to do to the my PUK off. When I open my LG shine it has this card-like thing and an arrow pointing to the right.. and i can only call emergencies. How do I get my regular phone back?
i have the same promble turns out the puk is on the back of the sims card.and now i cant do anything but get a new one
i have no idea how to get rid of the stupid puk block please can you help me
i no how to solve this problem you must call custemer servas and thay will tell u for free wat it is. but make sure u dont try and make up codes if u try and fail 10 times it fries ur sim card
I was messin around wit my phone and it locked me out now I have 3 more times I can guess and IDK what to do HELP
i was bored so i thought of seeing what else is on my phone. next thing i know its telling me to enter the PUK code and wont let me exit out. so i kept trying then the screen went to like a card thing with an arrow pointing saying insert simcard. and the only thing i can do is call 911 or 112.
help please, i really hope it didnt fry my sim card!
i did the same thing i just tried some numbers over adn over and now my stupid lg shine is n't doing anything!!! can anybody help me??
i was playing with the puk lock and i accidentally locked it
I got my phone activated in the morning and so i was trying to set a security code.then all of a sudden it was tellin me to enter the puk coke and wouldnt let me exit.then after ten times it was saying puk block and would only let me call 911 or112!! =c
please help =c=c=c
same here.
i was trying to lock my messages somehow but then i accidently clicked enter on puk lock and i dont know the code and i kep trying and then my whole phone locked and i took the sim card out and battery out and turned it off and back on :(!!!!!
SAMETHING HERE
i was messing with my phone, and i was stupid and locked it without knowing what the PUK code or PIN code was, and tried a bunch of random codes and now it says "PUK blocked" please help!!! i would really appreciate it!
i cant unblock it HELP
u sure that the solution #4 is correct.......please ..tell me thank u very very much
how can i unlock my lg shine out sim card
I was typing in PUK codes and none of them were right. Now my phone wont let me type any codes or call anyone accept emergency numbers.
i was typing anything then when i turn offf my phone it said puk blocked and was trying to unblock it but i dont know how to unblock the puk
how to unblock my phone
help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
what if you tried too many times and if completely blocked? what happens to the sim card??? do i loose everything:((???
i kept trying to unlock my phone and it kept asking for my puk code and i didn't know what it was so i kept trying now it wont unlock
well i was trying to lock my phone but it came up puk is blocked
i tried to set the security code if someone took my phone but then it said there was a preset one and then the puk thing came up and now i am locked out and my parents are really mad at me
i was using my phone and i was missing around with it i went to settings and it said something about a puk so i pressed there and it said to put a code than it said put a new code and confirm it i did this like 7 or 10 time than i tried to get out of it so i turned off my phone if it could exit it so i turned it back on and i thought it was goin to be back to normal but it wasnt it said puk blocked with a arrow on the pointing to the right wat should i do
i was being so stupid and messing around with my security till it started asking all these codes so i just was guessing and now i cold only do emergency call and that sucks!!!
blahhhhh shines suckkk.
qwertadfasdfasd
i kept trying the puk code and now my phone is blocked completly
same here OMG i hate this but i need help i've been trying for HOURS!!
OMG i have the same problem. so then i went on online and they said that if you try more than 10 times your sim card is invalid. which means you have to get a new sim card. i hate this.
My phone is totally blocked. I woke up and swithched it on and it said enter PUK code. Whats that and how do i unlock it??
my puk is blocked
Mine is blocked too i am bringing it in today to see what they say
i was messin with the security codes and i accidentally locked the PUK and idk how to unlock it can someone help?
are you serious. :| the sim card won't work like ever?
Is there not something that your service provider (mines rogers) can do for this issue ?
Solution link . . . www.LGShineKE970.com
