SOURCE: old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
SOURCE: Phone wont detect bluetooth H700
Mine could be discovered when powered off/ on my cellphone and retried... Sounds like solution to M$ programs, eh? :)
SOURCE: HS820 "dead"? No blue light
Toss it. They aren't replaceable. You have to break open the case (glued shut). Even if you opened it, the replacement would likely cost you what it would to replace the whole unit.
I'm in the same boat.
open the boom (mic) right when it turns to solid blue!
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=e4e6e7af976c9010VgnVCM1000008206b00aRCRD
SOURCE: I have a H270 Bluetooth headset. I charged it
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
