HI, have come home, and tried to put dishwasher on. Noticed the delay start is activated for 13:45 hours time. No other button will work, cannot eveb start/stop, or change programme. Have disconnected power, used manual to change settings as instructed, however nothing working, button wise. any tips?
SOURCE: miele dishwasher
My O/H found a considerable amount of gunge in the inlet pipe; that seems to have solved it! Thanks for your interest.
Enid
SOURCE: Change miele dishwasher door seal
http://www.partstap.com/ please go to this site for diagram please rate me thank you for useing fixya
SOURCE: Miele Dishwasher does not start
hi,
F51 fault is more than likely the heater relay is faulty but it could be your circulation pump is jammed up. if you are confident you can easily replace the replace the relay if it is faulty. you would need to put a meter across the terminals. if it is ok then the pump is blocked. if you are not confident you would require a service call. Miele have there own deadicated service team if you live in a metro area
hope this helps.
SOURCE: Dishwasher has set to 13
Did you try unplugging it ?......some will reset if you do ....if that doesnt work try pressing the set button and unplug at the same time.
