Question about JVC Audio Players & Recorders
I have a JVC TH-D60 dvd digital theater system. My problem is I can only get 2 speakers to work at a time. They all work but not at the same time
DVD movies are so recorded as to get specific sound from each speakers, for eg, if the scene involves a bee going in circles then, the sound is first heard from the left, the right, the back right and the back left, That should explain.
Posted on Oct 03, 2008
SOURCE:
Home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Aug 22, 2008 | JVC THD-50 System
Hi, I hve JVC TH G30 and i have connected my DishTV receiver (not HD) to the Aux port of the device. I can get sounds only on the front left and right speakers.. Is there an option to get surround for...
This is a 2-part question. You can get ALL speakers to SIMULATE a surround experience from ANY input, even 2-channel analog.
If there is an optical digital audio output on the Dish TV receiver use THAT and the TH-G30 can decode the surround audio properly.
Read up on surround modes in the manual.
Jun 07, 2011 | JVC TH-G30 Theater System
How do i hook up my tv to the sound system so i can hear regular tv through the speakers? I can hear it when i play a dvd but not regular tv shows.
The simplest way would be to run RCA cables from your Cable Box analog audio out (if THAT is where your TV programming comes from) to the available Audio In on the JVC. Page 9.
If the cable box has coaxial or optical digital audio OUT, run THAT (instead of the analog audio) to the correct Digital In connector. Page 8 and 9
This would free up the analog audio from the cable box to send directly to the TV's audio input for causal programming, like news, so you wouldn't need the JVC on.
http://www.retrevo.com/s/JVC-TH-D60-Home-Theater-Systems-review-manual/id/2771ag518/t/1-2/
Feb 07, 2011 | JVC THD-60 System
I HAVE A JVC HOME THEATER SYSTEM MODEL NUMBER TH-C5 THAT THE RECEIVER POWERS UP BUT THE SUB WILL NOT AND THE SPEAKERS ARE NOT WORKING.
Page 42:
No sound. The system cord and/or speaker cord is not connected. Check the connection.
The audio cord is not connected to AUDIO IN (VCR)
and/or DIGITAL IN (DBS) correctly.
Connect the cord correctly. (A pg. 13)
An incorrect source has been selected. Select the correct source. (Apg. 17)
The decode mode is not set correctly. Select the proper decode mode. (A pg. 35)
http://www.retrevo.com/support/JVC-TH-C5J-Home-Theater-Systems-manual/id/318ag518/t/2/
Do you think the powered subwoofer itself might have a power problem? Check its cord.
Dec 26, 2010 | JVC THC5 Home Theater System with 5-Disc...
I have a JVC G40 DVD home theater system and when I play DVD's the voice and picture don't match up. Specifically, Peoples lips move and then a second later what they say is heard...how do I fix this?
When viewing on Digital TV:-
Sometimes Audio and Video signal can not be transmitted simultaneously due to additional process time for the video signal compared to that of the audio signal.
Often video signal takes more time than the audio signal to convert from analogue signal to digital signal in the Digital TV.
It may result in mismatch of the picture and sound.
In the TH-G30/40's HD AV Sync menu, you can adjust the audio signal delay for simultaneous AV signal transmission
1. Delay time can be varied in 10msec steps.(0 to 300ms)
2. Delay time is different between TV Brands.
So you need to adjust the delay time for correct lip-sync.
The adjustment is listed in the instruction book page12
Jun 26, 2010 | JVC TH-G30 Theater System
JVC TH-C30 Digital Theater System
If there is no power at all, then try bypassing surge protector, check power cable, and check if power cord is fused.
If unit has power but does not start, then it is on protection.
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Mar 11, 2009 | JVC SP-PW100 Subwoofer
No sound from all speakers except front left and front right
Check the cables from the DVD to the Amp and make certain your in Dolby Digital mode on player.
Jan 24, 2009 | JVC TH-G30 Theater System
JVC TH-M45
no, u cant use the speakers with other normal DVD player because it wont have amplification for the speakers... u can use the sub to other dvd player because its inbuilt 120 watt woofer. ur dvd player is 5-disc player as wel as 120 X 2 and 80 X 3 watts amplifier (AV receiver ).... so just the JVC better sound thru the sub and speakers... ENJOY
kanny_amancha@yahoo.com
www.kanny-sounds.blogspot.com
Jan 24, 2009 | Pioneer 1000 Watt 5.1 Surround Sound...
156 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
