Question about Canon Office Equipment & Supplies
How do i clear system error E100 on an IR 10181 canon machine and what may be causing this error?
System error E100 on an IR 10181 canon machine
    New Friend:
E100 0000 BD detection PCB failureThe BD detection PCB is faulty. - Check the connector of the BD detection PCB.- Replace the laser scanner unit.- Replace the DC controller PCB.
Posted on Dec 14, 2011
  • bashir May 01, 2012
    well we are still seaching for the result we get back to you soon thanks
    New Friend:
  • 34 Answers
While what Dimitri said is true, you can also check the drum unit. There is a flag on the left rear(when holding it by the handles)that actuates the laser shutter. if the flag is missing the shutter doesn't open there for you get an E100 error. Could be as easy as replacing the drum.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_45d8d6c78cd9f0b6
Posted on Nov 26, 2014
SOURCE:
When to change laser unit of canon ir3300
Changing of laser is not essential...if your machine shows error E100-0001, E100-0002, E100-0003 & E110-0000 you will be must change the laser unit...
Jun 27, 2016 | Canon IR 3300 Digital Copier
System error E100 in canon ir 1610 how can I clear it. My machine was working I just desided to blow it, it was too dust. That's when the error started. Please help
When you were blowing dust you would have forced a leaf switch sensor into ON position hence this error NEVER BLOW TO CLEAN DUST ALWAYS SUCK DUST OFF INTO CLEANER . A simple tap with your palm all around the printer could set it back if not pro service
Jun 26, 2015 | Canon Office Equipment & Supplies
Error E100 on Canon iR1024A
Problem with Canon IR1024 Now the screen is reading System Error E100 PLEASE HELP!!
Jan 31, 2013 | Office Equipment & Supplies
DEAR SIR, MY CANON IR 400 MACHINES COPY IS TOTALLY BLACK .I WILL NOT HAVE ANY TYPE OF KNOWLEDGE . PLEASE GIVE THE ANY RESOLUTION, FOR GET CLEAR COPY OR ANY TYPE OF FUNCTION IS USE FOR CLEARING...
I will tell you the problem but you need Technician. First try cleaning/replace the flash rom or change tthe Camera together with the CCD Board.
May 11, 2011 | Canon imageRUNNER 400S Copier
Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
Jul 15, 2009 | Canon iR 2016i Black and White Copier
System Error E100
Most likely, the tab on the rear side of drum unit has broken off. Thus causing the Lazer Shutter not to open. There are 3 or 4 other possibilities other than replacing the drum unit.
Jun 02, 2009 | Canon iR 2020i Laser Printer
Solve System Error E100
Hi
E100 is laser related error.
You can try to reconect the conectors on dc controler board, and on laser unit, clean the laser, check if the laser shuter is broken.
If notthing helps the next step would be to chnage the laser unit and/or dc pcb
Ir 2010
The most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to opperate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
Sep 28, 2008 | Canon iR 2016i Black and White Copier
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
1,191 people viewed this question
Clive
Clive
old marine
old marine
