SOURCE: Sharp AR-5320 Driver
Appreciate the direct "Ask Me". For Sharp AR5316/AR5320 drivers, pls click here. The drivers are for Windows 95, Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP only.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
SOURCE: I WANT TO DOWN LOAD SHARP AR 5320 INTO MY CD
www.sharp.com, look for support/drivers and find your product. Download. Simple as that
SOURCE: dispays h4 error
An H4 error code indicates trouble in the fusing section - a certain temperature has not been reached within a specified time. It could mean a dirty/bad thermistor or dirty/bad thermostat (both inside the fuser unit. Make sure both of these are clean and there is not debris/paper stuck inside the unit.
You can try resetting the code by : Get into SIM mode by pressing the following keys one after the other "#" "interupt" "C" "interupt" then enter 14 and the start key - confirm if requested then make sure the copier restarts.
Hope this helps.
