BOTH REFRIGE AND FREEZER QUITE COOLING. FAN AT BOTTOM OF REFRIDGE WAS MAKING A CONSTANT WEIRD NOISE. I UNPLUGGED IT FOR NOW. THE UNIT HAS QUITE COOLING BEFORE AND SEEMED TO RESET ITSELF TO WORK PROPERLY AGAIN.
SOURCE: control panel for freezer and refrigerator
Behind the back panel of the freezer section is the evaperator assembly. on the rh side of the evaperator is a sensor pack that is for the defrost cycle. there is a thermo fuse inside of this pack that is open. The fridge goes into an error state if this fuse is open. unplugging the fridge resets the system. the sensor pack will have to be replaced.
SOURCE: frigidaire side by side refridge
pull the kick plate off under the doors. if you look in behind the kick plate youll see alot of dust build up. this area needs to be cleaned once a year to keep air flowing properly over the condenser coils. if the dust build up is minimal then remove back panel of refrigerator and make sure the fan is running behind the refrigerator. if not, or if running real slow replace the fan motor. the heat is the because the condenser is getting too hot. it needs to be fix or the compressor life will be greatly shortend
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
SOURCE: FREEZER WILL NOT GET COLD THE REFRIG SIDE WILL NOT GET COLD
if compressor not working u will need the main board
Let freezer get down in temp and fridge should start chillg.Good luck
