Question about Cisco ASA 5510 Firewall
Underrun and overrun errors on the asa 5510 ios8.2.0
We have underrun and overrun errors on the interface inside and outside of the asa 5510. we have fixed speed and duplex to auto in all interfaces of the asa. the asa is connected to 6509 in the inside and to a switch, witch is connected to a routeur, for the outside interface. connection internet is very slow. we have also drop input and output packets in inside and outside. Thanks for the answers and help.
SOURCE:
  • 3 Answers
SOURCE: installation of cisco asa 5510 firewall
Hi Jaaya, Well, unless you are very familiar with configuring cisco routers, you have set yourself up for a headache -- cisco routers are not user friendly, and many require being configured from the command line. I would suggest that you find a friend or hire a trained expert to help you configure your router with you, as any mistake or misconfiguration could create bigger problems down the road (many of the security problems organizations have are the result of misconfiguration). But, if you really would like to try, consult cisco's website (www.cisco.com), as well as these two pages (http://www.cisco.com/en/US/docs/security/asa/asa72/asdm52/user/guide/getstart.html) and (http://searchnetworking.techtarget.com/tip/0,289483,sid7_gci1140584,00.html) which specifically talk about asdm configuration. Good Luck!
Posted on Jul 30, 2007
SOURCE: Export and import all configuration in Cisco ASA 5510
Hello ,
the Steps which u want to export and import configuration in Cisco ASA5510
1- connect yourself to your Cisco gateway by IP
2- Get TFTP server to your PC like( solarwind , Tftp server , ... ) any tftp download and upload program
3- now u need to copy running configuration to your pc by order
#copy run tftp , then follow the steps
NOTE: u should be in the same network or u need your pc and cisco box both have publick IP
4- if u want to put prepair config files to your gateway , you will need to type order
#copy tftp run , then foloow the steps
If u need anything else please let us know by leave your completely request or join us with www.fixya.com
Regards,
Samer
Posted on Feb 11, 2009
  • 16 Answers
SOURCE: Activation key
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step 1
Obtain the serial number for your security appliance by entering the following command:
hostname# show activation-key
Step 2
Access one of the following URLs.
Use the following website if you are a registered user of Cisco.com:
http://www.cisco.com/go/license
Use the following website if you are not a registered user of Cisco.com:
http://www.cisco.com/go/license/public
Step 3
Enter the following information, when prompted:
Product Authorization Key (if you have multiple keys, enter one of the keys first. You have to enter
each key as a separate process.)
The serial number of your security appliance
Your email address
An activation key is automatically generated and sent to the email address that you provide. This key
includes all features you have registered so far for permanent licenses. For VPN Flex licenses, each
license has a separate activation key.
Step 4
If you have additional Product Authorization Keys, repeat Step 3 for each Product Authorization Key.
After you enter all of the Product Authorization Keys, the final activation key provided includes all of
the permanent features you registered
Posted on Feb 12, 2009
taran_2005
  • 10515 Answers
Hello kuniksh,
Look at the below link for all configurations
http://www.akadia.com/services/cisco_router_firewall.html
Do rate this solution!!!!
Posted on Mar 22, 2009
  • 8 Answers
SOURCE: Restart Cisco Asa 5510
Yes. The firewall will restart. Just be sure to save your running config to memory before turning off. For that you must issue the command: write memory.
Best Regards,
T
Posted on Apr 23, 2009
When i create a access rule on the outside interface, it creates a duplicate access rule on the inside interface. How do i stop this from happenning?
Although I can't find anything specific about this, I am sure from experience that the access-list is applied to both interfaces because of the way that the firewall simply passes traffic through the interfaces, as they are not seen as a hop, nor do they have IP addresses allocated to them. If the access list has a source and destination, in theory it doesn't matter which way the packet travels it will still be seen and thus inspected on both interfaces.
I hope that this has been of some help, sorry I couldn't be 100% on the answer, but as I said, from experience I believe this is correct.
If you want any forther information, there is quite a lot of documentation on Ciscos site:
http://www.cisco.com/en/US/products/ps6120/tsd_products_support_series_home.html
and something you might be particularly interested in is:
http://www.cisco.com/en/US/docs/security/asa/asa83/asdm63/configuration_guide/config.html
This is the configuration guide for ASA5500 via ASDM.
Hope that this has been of some use to you :)
Oct 13, 2010 | Cisco ASA 5510 Firewall
I have cisco asa 5510 firewall and i have dialup internet connection i want my asa 5510 between my LAN and my dial up internet
Your best bet is to place the ASA into 'transparent' mode, and letting the traffic pass through it and be inspected on the way through.
To do this you need to first do the following command:
firewall transparent
Once in transparent mode, the firewall will no longer look like a hop in the packets journey, and you can set rules to allow/disallow traffic using access lists on the inside and outside interfaces, plus you can perform packet inspections using policy-map and inspects.
Hope that helps!
Feb 12, 2010 | Cisco ASA 5510 Firewall
Replacing a PIX 515E with an ASA 5510
Best way to migrate is to take the configuration of the old PIX and TFTP it to a PC or other server for safe keeping.
Then boot up the ASA in a lab environment and TFTP the configuration to the new unit and reboot. There will be some commands that don't translate correctly, but you can compare the configurations to each other to make sure all the access lists and NAT statements get transferred across.
Keep in mind that the PIX and the ASA name their interfaces differently, so there may be errors when you transfer the configuration. You can edit the configuration offline with something like Notepad and change the names of the interfaces to have it work.
Jan 29, 2010 | Cisco ASA 5510 Firewall
How to counfugre asa 5505 cisco Router
Use the Cisco ASDM or SDM software, that will give you an easy graphical interface to configure the ASA. One of them would have been shipped with the device.
Don't forget the ASA has to pre-configured, just a simple config. Have HTTPS enabled and telnet/SSH helps as well if you dont have a serial port or the console cable.
Cisco's website will give you quite a lot of info for free...
Jan 18, 2010 | Cisco ASA 5505 Firewall
New cisco asa 5510 setup
connect your laptop to the asa5510 using a cross over cable
Oct 07, 2009 | Cisco ASA 5510 Firewall
How to configure static route between 2 LANs?
the command what you have given is correct as per your explanation. If you could post the configuration, it will be good to fix the issue.
Jun 10, 2009 | Cisco ASA 5510 Firewall
1. Change your PCs default gateway to your firewalls' internal IP
2. configure the nameservers on your ASA
Then internet will work fine.
May 23, 2009 | Cisco ASA 5510 Anti-X Edition...
IPSEC problem between ASA and Microsoft ISA
can you try lower encryption levels on each device and see if that helps? sometimes it is neccesary between Cisco and other devices.
May 18, 2009 | Cisco ASA 5510 Firewall
Best Regards,
T
Apr 18, 2009 | Cisco ASA 5510 Firewall
ASA 5510 sec - bun k9
Basic Commands pixfirewall(config)#hostname PIX !--- Naming the PIX is optional. PIX(config)#nameif ethernet2 fo security20 !--- Naming the interface is optional. It is recommended that you !--- hardcode the speed/duplex. PIX(config)#interface ethernet2 100full !--- Bring up the interface. PIX(config)#ip address fo 192.168.1.1 255.255.255.0 !--- Assign an IP address. Failover Commands PIX(config)#failover ip address fo 192.168.1.2 !--- IP address for the failover link. PIX(config)#failover lan unit primary !--- This unit is primary . PIX(config)#failover lan interface fo !--- The 'fo' interface is used for LAN failover. PIX(config)#failover lan key cisco !--- The Pre-shared key. PIX(config)#failover lan enable !--- Enables failover. PIX(config)#failover !--- Start the failover process. This message appears on the console:
LAN-based Failover: trying to contact peer failover_01.gifLAN-based Failover: Send hello msg and start failover monitoring
Nov 27, 2007 | Cisco ASA 5510 Firewall
Cisco ASA 5510 Firewall Logo
944 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
