Computers & Internet Logo
Anonymous Posted on Dec 13, 2011
Why i cant burn cd' or dvd on my computer
Nanny
Level 3:
Genius:
  • Gateway Master 2,351 Answers
  • Posted on Jun 27, 2019
Nanny
Gateway Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989333
Points
7262
For burning a DVD, it should be noted that for every file to DVD burning, these things should be prepared:
  1. Blank and writable DVD disc;
  2. A DVD recorder drive;
  3. An MP4 to DVD burner program.
You can try Leawo DVD Creator with which you can easily convert and burn AVCHD to playable DVD disc for playback on your home Blu-ray Disc Player.
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 268 Answers
  • Posted on Dec 13, 2011
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
268
Questions
0
Helped
62182
Points
563
I have used a DVD Ripper to burn DVDs,which one are you using,you may have a look at this one.
It is on one hand is a professional DVD to Video converter for you to rip, backup, edit and convert DVD to video in variety of formats.
2answers
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
2answers
Hp g56 129wm laptop cant log on at all need password
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
2answers
Why i can't burn dvd or cd on my computer
you will need software like NERO to burn cd or dvd select the option (burn image to disc) for mp3 cd to play on all cd players or if you try this go to your downloaded file and clik once left then once right clik then you see the option (send to) put cursor on that option then then another menu will come up then select your dvd drive if you cannot play that dvd after its burned you might need either dvd creator software or you might need a dvd player with Divx capability...you might already have dvd and cd burning software already on your pc like power producer im sure you'll get it on piratebay.org if you download utorrent first<(FREE) hope this helps be carefull of viruses on pirate bay
2answers
How do I format a dvd disc
You don't have to. DVD's and CD's are already formatted from factory. But if you are having problems to record on (burn) them probably your computer is not capable for DVD burn, just CD's. But if it is equipped for burning then try this:
See alsoFormat a CD or DVD
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting. There are several ways to format a CD or DVD disc. Your choice of format determines which computers and other devices will be able to read the disc.
  1. Insert a disc into your computer's CD or DVD drive.
  2. In the dialog box that appears, click Burn files to disc.
  3. In the Burn a disc dialog box, type a name for your new disc.
  4. Click Show formatting options, and then click one of the following formatting options:
    • Live File System
    • Mastered
  5. Click Next to prepare the disc.
    Now you can copy files to your disc using whichever method you selected.
I have a hp compaq 5100 sff with a combo dvd/cd rewriter went out bought the blank dvd+rw disc but i cant get it to burn dvd's it burns cd's but not dvd
Go and buy some dvd- as this is probably what your dvd drive writes to, and not dvd+, the most common disc is the dvd-
hope this helps
1helpful
2answers
MY PC has sony DVD-ROM DDU1615 that I can't record my videos onto a dvd
you cant burn a disk with a dvd rom
you will need both a dvd rw unit and a dvd rw disk to burn any video to a disk if you have both of these the burning program might not support video burning or you might not have selected the right option there are lots of free burning software programs that can burn videos to a disk you might have to burn it as an ISO image
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
hope this helps
Cant burn Cd's or DVDs
Spend $40, and buy a replacement CD/DVD reader/writer -- much better than taking the computer to a technician, and paying the technician $25 to $65 to "trouble-shoot", only for him/her to recommend that you need to buy a replacement.
1helpful
3answers
I cant burn videos from my laptop to dvd.i have dvd rom in m laptop.i can burn on cd but cant do it in dvd, can you solve this problem?
you need a dvd burner install in your pc the dvd row just reads dvds and you what to contact a local store to do that thanks`
Transfering photos from computer to cd/dvd
you cant transfer those to cd without doing the process of Burning them to the cd/dvd.
if the pics/vids are already there on your computer, use Nero as your burning software and burn them to a blank cd or dvd. the process is simple enough. there are ways on how to burn images to a cd or dvd with nero.
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
