Computers & Internet Logo
Anonymous Posted on Dec 13, 2011
Why i can't burn dvd or cd on my computer
Nanny
Level 3:
Genius:
  • Gateway Master 2,351 Answers
  • Posted on May 08, 2019
Nanny
Gateway Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989318
Points
7262
First, you need to make sure that your computer is equipped with a DVD drive and the drive should be able to write data in addition to reading data. Then you also need a DVD burning software tool to help you burn the dvd such as Leawo DVD Creator and Burnaware.
sean o connell
Level 2:
Scholar:
  • Expert 131 Answers
  • Posted on Dec 13, 2011
sean o connell
Expert
Level 2:
Scholar:
Answers
131
Questions
12
Helped
14616
Points
201
You will need software like NERO to burn cd or dvd select the option (burn image to disc) for mp3 cd to play on all cd players or if you try this go to your downloaded file and clik once left then once right clik then you see the option (send to) put cursor on that option then then another menu will come up then select your dvd drive if you cannot play that dvd after its burned you might need either dvd creator software or you might need a dvd player with Divx capability...you might already have dvd and cd burning software already on your pc like power producer im sure you'll get it on piratebay.org if you download utorrent first<(FREE) hope this helps be carefull of viruses on pirate bay
2answers
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
2answers
Windows log in
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
I don't know how to download cd's and dvd's on dell EL-1210-09
What do you mean download cd's and dvd's? You don't download them, you simply put them in the drive and play them. If you purchased a music cd or a movie dvd that you want to play or watch, then just put it in the drive. The system will recognize it and automatically open Windows Media Player for you to play it or you can open it yourself if autoplay is not active.
Exactly what is it that you are trying to do?
If you are talking about putting a blank cd or dvd into the drive to copy music or a movie to it, that's another story and will take a while to explain. You will basically need to make sure your CD/DvD drive can burn CD's or Dvd's. Then you will need some type of burning software (later versions of Window Media Player will burn).
Click Start/My Computer and look at your devices. if your DvD/CD Drive is listed look for RW which means rewritable (it can burn or copy). If it say DVDrw it can read and write dvd's. If it says CDrw it can read and write cd's. You can also look on the drive door on the computer where you would place the cd or dvd. If it says Rewritable CDrw (it can write cd's) or DvDrw (it can write dvd's). If it says ROM (read only media), that means it can Read Only and not write.
If the drive is rewritable then the software such as Media Player will allow you to go find what you want to put on the cd or dvd. You have two ways of putting things in the software to burn or write. You can copy and paste, or you can drag and drop.
L305D-S5930 dvd wont burn documents to a dvd disc
You need a program, like nero.
if that doesn't work then put a DVD in the drive & see if the computer picks it up in the my computer.
the first thing that goes in a CD/DVD-RW drive is the DVD heads, thats if your drive is a CD/DVD-RW.
Have a look on the front of the drive tray, if it say CD-RW DVD ROM then it doesn't burn DVD's it only plays them.
2answers
How do I format a dvd disc
You don't have to. DVD's and CD's are already formatted from factory. But if you are having problems to record on (burn) them probably your computer is not capable for DVD burn, just CD's. But if it is equipped for burning then try this:
See alsoFormat a CD or DVD
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting. There are several ways to format a CD or DVD disc. Your choice of format determines which computers and other devices will be able to read the disc.
  1. Insert a disc into your computer's CD or DVD drive.
  2. In the dialog box that appears, click Burn files to disc.
  3. In the Burn a disc dialog box, type a name for your new disc.
  4. Click Show formatting options, and then click one of the following formatting options:
    • Live File System
    • Mastered
  5. Click Next to prepare the disc.
    Now you can copy files to your disc using whichever method you selected.
Trying to burn a movie from a new burner by samsung 22x 768564 dvd, but the green line doesn't keep up with the timer, i let 1 movie burn for 12 hours on timer and all it did was encode, didn't...
should not take 12 hrs to burn
does it burn data cd/dvd or audio cd/dvd's ?
you might have to burn it as an ISO image
this might be because you have not selected the option to burn a dvd movie you might have selected another option ie:burn data audio or your burning software does not support movie dvd burning
there are plenty of free burning software programs on the internet
http://www.majorgeeks.com/BurnAware_Free_d5839.html
BurnAware Free is one of the most popular free CD, DVD, Blu-ray Disc burning software available for Windows.
Using this program you can easily create and burn Audio and MP3 CD, Data and DVD-Video disc, ISO and Cue Image,
erase or format rewritable disc, copy your CD or DVD to ISO image.
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
I have been Trying to burn CD's using Windows Media and the burner I have is a Philips version. The computer is a dell demision 4700 from 2005 or so. I keep getting messages saying disc is dirty or use...
this might be the burning software program you are using
there are many freeware burning programs on the net
what sort of cd disk are trying to burn ie: data media iso........
how many disks does this happen to ? ?
the cd's you have might be a bad batch!!!
can you burn dvd's ??
hope this helps
3answers
I dont know how to burn a movie to a blank dvd
open up your burning program depending on which burning program you have you can select either dvd or cd to burn an iso or make a cd/dvd movie once you have made your choice a browser should open navigate to your video file/s select it you might have to select an iso
((will depend on which burning program you have)) add to you should a graph oh how many mbs have been used once it loads select burn
if you dont have any burning software to burn dvd's
http://download.cnet.com/burn4free-cd-and-dvd/3000-2646_4-10217894.html
Burn4Free CD and DVD is a burning solution that's compatible with more than 3,000 DVD, Blu-ray and CD burners. Burn data and audio from different file types (WAV, WMA, MP3, OGG, FLAC, WavPack, and CDA). Burn and save ISO files, open and save your project to disk, verify content, print compilations, copy DVD, copy BLU RAY and import your audio compilation from M3U and ASX playlists. The drives supported include dual-layer DVD, CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM, BD-R, BD-RE (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
hope this helps you
2answers
How do you take a moive on the compter to a c d
I assume you mean a DVD. A DVD would be able to be used to watch the video in DVD Players and other computers. However, burning it to a CD would be usuable to as it would just act as a storage media but wouldn't be able to be played in a standard DVD player. To burn a DVD/CD you must first have a CD/DVD Burner. It is a CD Drive witht he capability to burn CD/DVD. Then you can just use any video burning software, such as Windows Media Player or iMovie (on mac) to burn the video on to your CD/DVD.
1helpful
Can't find my owners manual, what kind of DVD's would my Acer Aspire Z5700 use?
The Acer Aspire Z5700 Desktop Computer includes a slimline CD/DVD burner capable of burning the following media: CD-R, CD+R, CD-RW, CD+RW, DVD+R, DVD-R, DVD-RW, DVD+RW, DVD-R DL (double layer), and DVD+R DL (double layer).
Basically, this computer can burn to any type of recordable CD/DVD media except for BluRay.
If you find this solution helpful, please leave a positive rating!
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
