Problem with Canon IR1024 Systems Error E100 Now the screen is reading System Error E100 PLEASE HELP!!Problem with Canon IR1024 Systems Error E100 Now the screen is reading System Error E100 PLEASE HELP!!
Problem with Canon IR1024 Now the screen is reading System Error E100 PLEASE HELP!!Problem with Canon IR1024 Now the screen is reading System Error E100 PLEASE HELP!!
cannon ir1020 first problem was paper jam even all jammed paper's removed, the second one is code error E100.cannon ir1020 first problem was paper jam even all jammed paper's removed, the second one is code error E100.
Problem with Canon IR2016 Systems Error E100 Now the screen is reading System Error E100 PLEASE HELP!!Problem with Canon IR2016 Systems Error E100 Now the screen is reading System Error E100 PLEASE HELP!!
Yes the drum can cause this error. However if it isn't the drum it is either the laser or DC controller. When you insert the drum there is a flag on the rear as you insert it that open the laser shutter. if the shutter doesn't open then you will get the code.
Hello, E100 is error for laser unit. Probably the jam occured because fault on laser unit. To fix error you need to reconnect all connectors of laser unit, or in worst case replace laser unit completly.
In future, please follow these instructions and/or these to clear a paper jam on your printer. This article describes how to reset the printer to clear the ink system failure error.
For other questions, please see your hp home support page here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
hi, CANON PIXMA MP160 All-In-One InkJet
Printer has few common problems. Such as Driver CD
lost, Scanner does not work, Connection problem etc. For find all these software solution
just click here....
Open door to see whether do you do have any paper jammed. Sometimes, printer does not have a paper jammed but error still appears out of no where. Just open the door and close it again.
Thanks a lot I think it can be this problem
