Unable to connect my sony psp to the internet using my sky modem using wi-fi
keeps getting error message
" A connection error has occured.The attempt to obtain the ip address timed out"
GRAND THEFT AUTO VCS ITS COOL BUT HOW T O GET CUSTOM FIRMWIRE I HAVE CHEATDEVICE THATS WHY IT GOS HARDGRAND THEFT AUTO VCS ITS COOL BUT HOW T O GET CUSTOM FIRMWIRE I HAVE CHEATDEVICE THATS WHY IT GOS HARD
I have entered the correct WEP key for the wireless connection but every time I try to do something that has to do with using the internet it says: A connection error has occurred (80410AOB). It just doesn't make sense.I have entered the correct WEP key for the wireless connection but every time I try to do something that has to do with using the internet it says: A connection error has occurred (80410AOB). It just doesn't make sense.
You can't post conmments that contain an email address.
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet. Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
i would be glad to assist you with this.
Instructions
Take out the UMD disc from the back of the PSP if one is inserted.
Take out your memory card from the memory card reader if one is inserted.
Turn on your PSP.
Go to the "Settings" tab in the Cross Media Bar and select "System Settings."
5
Select "Restore Default Settings" and confirm that you wish to restore all settings to the
factory defaults.
6
Restart your PSP.
7
Try connecting to the Internet again. If you still get the error, try connecting to
another network. If you successfully establish a connection to another network, your router is at
fault. If you cannot connect to the second network, your PSP's Wi-Fi card could be damaged and
may need repairs.
Tips & Warnings
Ensure that you are entering the Wi-Fi SSID and password correctly on the PSP.
You can contact PlayStation Support (see Resources) to start a repair order if you PSP's Wi-Fi
card is faulty.
if you require further assistance please let me know and i will be glad to assist you. Thanks
try this
Instructions
Turn on your PSP.
5
Select "Restore Default Settings" and confirm that you wish to restore all settings to the factory defaults.
6
Restart your PSP.
7
Try connecting to the Internet again. If you still get the 80410A0b error, try connecting to another network. If you successfully establish a connection to another network, your router is at fault. If you cannot connect to the second network, your PSP's Wi-Fi card could be damaged and may need repairs.
Tips & Warnings
You can contact PlayStation Support (see Resources) to start a repair order if you PSP's Wi-Fi card is faulty.
Please make sure the wi-fi switch by the side of the PSP is on, if this is true then verify with your network administrator about your wi-fi if it's secured. If it's open then you can go ahead and run the wi-fi search on your psp and connect appropriately.
You can set it to automatically obtain IP addresses.
id be happy to help
Instructions
Turn on your PSP.
5
6
Restart your PSP.
7
Tips & Warnings
You need to "authenticate" the wireless meaning you need the password to the web signal. Your phone may have an internal software issue in which it prevents you from connecting to the internet. Contact your phone company to trouble shoot it or get a replacement phone.
i can assist you with this.
Instructions
Turn on your PSP.
5
6
Restart your PSP.
7
Tips & Warnings
i have the same problem
it keeps on saying connection error
i had the same problem with my psp but i still havent fixed it plz help
i can put music on it what do i do
