Runs for a few minutes then shuts off, easy fix. First, remove water catcher and slide filter out and clean it. Then find the two screws that hold on the front panel remove front panel. Make sure the unit is un-plugged. The humidity control dial has two wires connected to it. clip the inner wire. This will keep the unit on full. You could replace the humidity control dial, but why bother?
SOURCE: Goldstar DH304 Dehumidifier
Take cover off. First check the fuse on the circuit board. If it's blown replace it. That should get the motor running, the motor might be or is going out. If the motor is bad you'll have to replace the motor. If the fuse is good and the motor is good, unhook the wires on circuit board that go to the humidity control switch. If the unit comes on with the humidity control switch unhooked, you'll have to replace the humidity control switch. Sears has them for about $11.50. Hope this helps.
SOURCE: icing on back of coils on dehumidifier
could be dirt coils or low freon either way needs to be checked
SOURCE: goldstar dehumidifier dh305t7
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=DH504ELY6&matchedModelCode=NOT_MATCHED&searchEngineModelCode=DH504ELY6&initialTab=documents&targetPage=support-product-profile#
Only available for DjVu reader (download link on LG site). You'll need to download and install the plugin then close and relaunch your browser. I was only able to get it to work in IE in the end with Firefox and Chrome not working. IE objected I had to "allow" the plugin to run then once again close and relaunch the browser then it finally worked. Good Luck!
SOURCE: I noticed today our Goldstar
That's an indication, that the filter needs to be removed and cleaned.
Turn the unit OFF & unplug it before removing the filter. You can vacuum the filter or if it's really dirty, wash it in warm water and dish washing liquid. Rinse thoroughly and allow to completely dry, before reinstalling. Never operate the unit without the filter installed.
If the coils continue to frost, but not defrost, they also should be cleaned.
