You can try GT Recovery for Windows which can recover deleted messages without root your phone!
no root !
Can you retrieve deleted text messages on Android? Yeah, this video will show you the full guide for Android text message recovery. Don't hesitate and recover deleted text messages from Android 4.0, 4.1, 4.2, 4.4, 5.0, 5.1 and more versions right now!
Not only can you recover SMS messages from Android backup but also can recover Android SMS messages without backup. This video is showing you how to recover deleted sms messages on Android without root your phone.
Some common situations that lost text messages you can recover from:
1. accidentally deleted texts on your android phone
2. lost text messages after Android 5.0 updated or other Android upgrade.
3. save text messages from water damaged, crashed, broken or smashed Android phone
4. Android deleted text messages randomly by itself
5. Factory restore Android phone.
And more...
Facebook Homepage:https://www.facebook.com/GT-Recovery-for-Windows-527139864132104/
Google+:https://plus.google.com/communities/109657948177651590858
Download link: http://www.gtrecovery.net/
SOURCE: installing java games for samsung star 3g s5603
since it is a java operating system you shouldn't have any problems installing java games. As far as internet, what are you looking at?
SOURCE: recovering deleted txts
No hope.
If you would like to download the third party program. You can read this article. It tells you how to recover deleted text from mobile memory.
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio.
