Question about Cell Phones
Its saying enter network key - Cell Phones
    New Friend:
  • 8 Answers
What is Mobile Phone brand and model? You can unlock the mobile phone from Network lock using the Network key or Network Unlock code,You can get that from the site Superunlockcodes.com/unlock-your-phone/rs12wp2/ at low cost..You can get the free unlocking instructions from here Mobileunlockguide.com and unlock it from Network lock.
Posted on Dec 12, 2011
  • Cell Phones Master
  • 32,281 Answers
When you connect to your secured WirelessNetwork, it will asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_address
SOURCE:
I am trying to connect to a pocket wi fi. The manual says when connecting you may have to enter a password. is that for the pc or the wi fi device?
When youclick Refresh network list, then Choose yourwireless network and then click Connect to your secured WirelessNetwork, it will asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key.
Jun 29, 2011 | ASUS Eee 4G Notebook
I was connecting my siemens wireless router 6520 and i reset it after doing that the wireless light went off and would not work again anything i can do?
If you reset the router, you will likely need to go into the router's configuration through a wired connection and enable the wireless functionality of the router.
Please see the excerpt from the below website:
NOTE: The IP address in the example may differ than your actual IP
Please follow these steps to set up your a wireless network with your Siemens Speedstream 6520 Wireless Modem.
To create a wireless network you first need to enable the wireless functionality of the router. To do this you need to connect the router by an Ethernet cable to your computer. Once the wireless modem is plugged into your computer via Ethernet and turned on please follow these steps to enable the wireless functionality.
Open Internet Explorer or your preferred browser.
  1. In the address bar type 192.168.254.254 then press enter.
  2. This will bring up the main page for the Router.
  3. Once the start up page has loaded you will then need to login by clicking on the "Go" button in the top left of the window.
  4. This will bring up the Login page. Once the page has loaded please enter the username username and your password, then click "Log In".
Note: The default password is "admin", although this may have changed if you have changed the password.
Once this page has loaded click on "Home Network" and then click "Advanced".
Once the new page has loaded you will have a list of links, please click on the "Configure the Local Speedstream Gateway Wireless Network" link.
This will bring up a new page called "Wireless Summary".
Once this page has loaded place click on "Begin Wireless Wizard".
On the new page under where it says "Wireless Interface" please click "Enable".
Once you have changed the wireless interface to "Enable" please enter a name for your wireless network where it says SSID (e.g. "Home Office").
Then please click on the "Next" link.
On the new page, please change "Security Mode" to "WEP 64-bits" and click "Next".
This will bring up the "Wireless 64-Bit WEP Configuration" page.
On this page you will need to enter a passphrase to generate your WEP keys. We have used "icecream" but you can use anything. Once you have entered a phrase click "Generate Key".
This will generate four 64 Bit Key's. Please select any one of the four keys and click "Next".
Note: You will need the 64 Bit Key that you select in the future for devices to log on to the wireless network. Make sure you can remember your chose a passphrase that you will remember.
Once you have clicked "Next" a new page will load called "Wireless Filter Configuration". This is an advanced page for allowing access and denying access to certain computers or devices. We have set the "Wireless Filter" mode to "Disable".
Please click on the "Next" button to bring you to the "Wireless Options Configuration Page".
On this page pleas make sure that:
"Data Transfer Rate:" is set to "Auto"
"RTS/CTS Threshold:" is set to "2432"
"Fragmentation Threshold:" is set to "2346"
Once these setting are correct please click "Next" to bring up the "Wireless Wizard" page.
Once this page has loaded, you have finished enabling your wireless network so click "Finish".
This will bring up the "Wireless Summary" page again, but next to where it says "State" it should say "Enabled". Please ensure your settings are the same as the screen shot below ("SSID" and "Security Key Info" may be different").
If all these details are the same please click on the "Reboot" button to save the changes, and then once the new page loads click on "Reboot" to restart the router.
Once your modem has fully rebooted, please close your browser.
You are now able to unplug the Ethernet cable from the router and the computer.
How to connect other computers to your wireless network
On the computer you want to connect to the wireless network please follow these steps.
Once your browser is closed please click on the "Start" menu on the bottom of your screen, the click on "All Programs", hover over "Accessories", then hover over "Communications" and then click on "Network Connections".
Once "Network Connections" has opened under where it says "LAN or High-Speed Internet" please right click on "Wireless Network Connection" and then click "View Available Wireless Networks".
This should load the "Wireless Network Connection" window, and you should be able to see the wireless network you have set up.
Note: If there is nothing in your list you will need to click the "Refresh network list" button.
Once you see your network, make sure it is highlighted and then click "Connect".
Once you have clicked "Connect" it will ask you for your "Network Key". Please enter your 10 character key next to where it says "Network Key" and then retype the 10 character key where it says "Confirm Network Key".
Note: Your "Network Key" is the 64 Bit Key that you generated with a passphrase in step 16.
Once you have entered and confirmed your network key click on connect.
If everything is successful, the "Wireless Network Connections" window should say "Connected" next to your wireless network that you set up.
You should now be able to browse the internet.
May 06, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
My belkin has an orange color and i cant connect to my laptop because it has an red X saying the settings saved on this computer for the network do not match the requirements or the network Please help!
Hi lil_dreamer,
The Reason why you have that message is because the Network Key on the Router did not match the Network Key that you've entered on the computer to fix this you need to access your Wireless Settings Page and check the Network Key after that we will remove the same settings on the computer and add a new one.
To access your router just open a Browser then type 192.168.2.1, password is blank. Click on the Security under Wireless. You can change the security type of your rotuer to WPA, WEP or you can also Disable the security. Personalize the Passphrase or Network Key so that you can easily remember it.
Now that we have the information needed lest configure your computer.
- Click on Start or Orb.
- Click on Control Panel.
- Select Network and Sharing Center.
- Click on Manage Wireless Networks on left under Task
- Remove all the Saved Networks on the list.
- Click on Add.
- Select Manually create a network profile.
- Enter the Network Name (SSID), Select the Encryption Type (WPA,WEP,WPA2), Enter you Passphrase or Network Key.
- Put a Tick or Check on Start this connection Manually.
- Click on Connect. Wait for the confirmation and it will work fine now.
Don't forget to say thanks. Thanks for using Fixya.
Feb 05, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
When trying to connect to wireless network at home it asks for router pin then tries to set up new network. I want to connect to exsisting network
My friend,
Where it says for a pin .there is option below that screen "I want to enter passphrase"
Please select the option and enter your wireless network key.
You will be connected to the existing network when you will enter the key.
Regards:-
Amit
Jan 21, 2011 | Linksys Computers & Internet
On my Windows XP laptop I cannot get the wireless to work. All it says is "limited or no connectivity" when it connects. I have tried a million things, and nothing works! What can I do?
Disconnect your laptop wireless connection from the wireless acess connection. (Reboot your laptop if necessary). Then reconnect your laptop wireless connection, if your wireless network is a secured wireless network, your laptop will prompt for a network key ie your wireless network SSID password. Make sure the network key correctly entered ie.("Most wireless password keys are Upper or Lower case sensitive")
If the problem persist, then use the "Command Prompt"
Start ->"Run" ->Type "CMD" ->The command prompt will appear, then type ie without the quotes,
1. "ipconfig /release" -> enter
2. "ipconfig /renew" -> enter
3. "ipconfig /flushdns" -> enter
Hope it helps.
Nov 17, 2010 | Microsoft Windows XP Professional
How to find network key
hi guest,
step1:open up ur internet 2:Then:type this into the search bar 192.168.1.1 and press enter 3)It will ask for ur username and password type ur user name and password put admin 4) then you will get a page that says linksys 5) press :wireless 6) then wireless security 7) lastly u will see something that says "wpa shared key" and that is ur net work key
All the best give me a comment and rate..
May 20, 2010 | Computers & Internet
My phone nokia 6230 says enter restriction code
  1. Put the other network SIM card in your phone
  2. Press Undo Restriction
  3. Type #
  4. Then press the * key 3times (you should get a "p")
  5. Then press the * key 4times (you should get a "w")
  6. Then press the * key 2times (you should get a "+")
  7. Then enter: 415567734347577
  8. Then press the * key 2times(you should get a "+")
  9. Then enter: 7
  10. Enter: #
  11. So it should look like #pw+415567734347577+7#
If that code doesn't work try #pw+393406114166212+1#
Do not try this more than 5 times or you will need to unlock your phone via cable which will cost money. Contact me directly if it doesn't work.
Sep 01, 2009 | Nokia 6230
Unable to encrypt router
you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
Jun 04, 2009 | Belkin (F5D5231-4) Router
I cant access internet exp. from my laptop even with good signal
Access the preferred network settings (if you are using the Windows wireless setup - right click on the wireless icon + view available wireless networks + preferred networks) for your machine and edit the listing for your wireless network, you'll need to uncheck the box that says something to the effect of "an authentication key is provided for me" and enter your security key in the boxes provided.
If it still fails - you may want to remove your network from the preferred listing and add it manually, making sure that the authentication is turned off as described and with your security key entered twice.
Feb 23, 2009 | IBM ThinkPad R50e Notebook
Can not connect to internet on wireless acer laptop 5315. it says the settings saved on this computer for network do not match the requirements for the network
Your security key has perhaps changed.
You will need to check this key entered into your laptop against what is entered into the router.
Aug 30, 2008 | Acer Computers & Internet
Cell Phones Logo
216 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
