Eureka Mega Boss 4460DT Vacuum Logo
Susan Bellamy Chenevert Posted on Oct 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My eureka has no suction at all
When I vacuum there is absolutely no suction. I have taken off the hose but cannot find a blockage. What else can I do?
CJ C
Level 2:
Scholar:
  • Expert 66 Answers
  • Posted on Nov 29, 2008
CJ C
Expert
Level 2:
Scholar:
Answers
66
Questions
0
Helped
45591
Points
113
Try taking out the bag and checking to see if the inlet port onthe bottom of the inside of the bag bay is giving any sucion or if you can feel air rushing past your fingers. if there is then there is eiher a full bag, or a clog in oneo f the inlet ports going to the bag that the vacuum cannot clear. also make sure your filters are clear of debree and clean.
Eureka Boss Pro 411A has no suction?
Question edited for clarity and toss in a few CAPS.
Question moved from Cars and Trucks.
It has to be a blockage and on that one, either behind the brush or in the hose.
https://evacuumstore.com/s-2349-411a.aspx
https://www.google.com/search?q=Eureka+boss+pro+411+no+suction
Eureka Optima Lightweight suction weak on bare floor, hose only works when dial is turn to floor?
I think it is normal. My favorite setting is the dial is turned to bare floor. If you set your vacuum to hose, then you need to adjust the height (do not set the dial to the bare floor).
2helpful
Eureka Smart Vac The Boss no suction from either setting. I have taken it apart trying to see if it was clogged but it isn't. Checked the hose it is not sliced.
Remove the bag cover and feel for suction above the motor. If their is suction there then check the bag compartment is sealed. You can drop a coin down the hose to check for blockages all the way to where the bag attaches.
1helpful
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
1helpful
Vacuum shoots dirt or whatever it has just vacuumed out the back of the vacuum. I checked and cleaned the filter and the vacuum bag and it still leaves dirt behind the vacuum.
Good morning,
If you've checked both the bag and the filter, the next step would to check for any clogs.
I will detail what you will need to do below, or you can always reference your Owner's Guide (check: How to Check and Clear Hose Blockages)
http://www.eureka.com/service/manuals/77418_r2.pdf
Step 1: Remove hose from hose retainer on the base and check suction at end of hose - if little or no suction, check dust cup. Empty if needed. If no improvement, proceed to step 2.
(Make sure you turn off the switch and unplug the unit before proceeding to step 2)
Step 2: Remove electrical cord from cord hooks. Disconnect the clear tube by unscrewing the 2 screws, then lift away from cleaner. Check for any obstructions that may be in the tube or hose. Any obstructions can be removed by using a blunt instrument to clear the tube or hose (I will sometimes you a bent hanger or a retractable pointer). Flexing the hose may help loosen the blockage. After clearing blockage, reverse above steps to reassemble unitpcfloy86_0.jpg.
I hope this helps. If so, please give this solution a thumbs up!
Have a good day
~PCF
1helpful
No suction when vacuuming, but suction is good when using hose
check for blockage from where the hose sets in its
holder to the roller brush. Also see if the brush is
turning, the belt maybe broken.
Tom
Eureka rm 4480
Hi there SmartAlec from NelsonVacuums.com.au . Unless there is a bad sound coming from your vacuum i would suggest you have a blockage. This machine is prone to getting blockages in 3 different places.
  1. at the base behind the brush.
  2. Inside the main suction hose - this should be removeable so you can drop a small coin through. If it doesnt fall easily viola blockage found.
  3. Where the dirt enteras the chamber or bag.
Basically start by removing all hoses and filters and turn machine on put your hand over all inlet and exit points provided you can feel airflow at one of these points work backwards from there and identify the point at which you no longer feel airflow.
HAPPY vacuuming !
25helpful
4answers
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Top Eureka Vacuums Experts
Mike Cairns
Mike Cairns
Jo Ri
Level 1 Expert
Alexander
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
